Results 1 to 10 of 10
Thread: LM1 doesnt match EFI Live
    Jan 2006
    Default LM1 doesnt match EFI Live
    I noticed that the display and what the computer is logging doesnt match my display on my lm1. Its off by almost 1. In 4th gear wot the lm1 was reading 12.2 the computer was logging 13.1. I just switched to a new laptop so I must have something setup differnt than my old one. What do I have off?
    Jun 2005
    I noticed errors like this with my LC1. I was on the dyno at a local shop with a friend's car and the LC1 was reading 12.0, but the dyno was reading 13.0. I tried to get some answers from Innovate and they brushed me off saying something along the lines of it being the analog wires fault. There's too much room for error or something...
    Here's the thread:
    http://www.innovatemotorsports.com/f...ead.php?t=4118
    Jan 2006
    Hmmm. I wonder which one I should trust, efi or the lm1. The lm1 is reading 14.6/14.7 when at cruise so I would thing the lm1 is correct. EFI is reading high 15's. In closed loop the car isnt making any corrections either, so I would like to believe I have my VE table dialed in, because it was really off giving my an afr of 15-16 I would think I would see the car trying to correct for that.
    Jan 2006
    I plan on spraying a 100 shot on the dyno tonight if eveything on motor checks out. So if the lm1 is right then im safe at 12.2 if efi is right im going to have some major problems.
    Lifetime Member Garry's Avatar
    Jun 2006
    Are you using the LC-1 as output to both LM1 and EFILive? If so, are you sure the outputs are programmed correctly?
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Jan 2006
    Quote Originally Posted by Garry
    Yes using it for both. Thats what I am asking. I never noticed it before on my old laptop but on this new one it seems to be getting worse.
    Lifetime Member johnv's Avatar
    Jan 2005
    Quote Originally Posted by minytrker
    There is a tread here some where about altering the calc for voltage offset using a "voltage offset spreadsheet".
    Mine was off with the std calc in EFI, after altering calc it matches perfectly.
    Definatly trust the LM1 readout over EFI and make sure you do a free air calibration, preferably with sensor out of exhaust and engine running with a few revs so voltage from charging system is where it would be when logging .
    Jan 2006
    I checked the lm1 against the wb at the dyno and it matched perfect so that means I need to find that calculation for efi to correct it in there.
    Member bK's Avatar
    Mar 2004
    Do you know what your voltage offset is? It’s extremely hard not to get a voltage offset between your WBO2 and Flashscan.
    I setup my LC-1’d 2nd analogue output to push 2v no matter what the AFR is, on Flashscan that comes in at 1.97V so I use in my calculations to correct the voltage offset to get my correct AFR reading in Flashscan.
    I posted how I fixed the voltage offset on this topic> http://forum.efilive.com/showthread.php?t=1530&page=3
    Quote Originally Posted by bK
    LC-1 is wired in and working perfect..... Well almost perfect it's got the slightest ground offset of 0.03. I've worked this out from changing analogue 2 output to a flat line of 2V at 10:1 and 20:1 AFR. The reading I get from the Flashscan is 1.97V.
    So to get my the calculation for correct Wideband AFR to work perfectly I need to modify the SAE_GENERIC.txt from:
    ({EXT.AD1}*3)+7.35 TO
    (({EXT.AD1}+0.03)*3)+7.35
    Chassis by Holden
    Engine by Chev
    PCM modified by Flashscan
    Cam by Comp Cams
    Jun 2006
    I setup my LC-1’d 2nd analogue output to push 3v no matter what the AFR is, on Flashscan that comes in a 2.98V so I use in my calculations to correct the voltage offset to get my correct AFR reading in Flashscan.
    That's a good suggestion! Maybe this should be added to the LC-1 install how-to ... .02V already can make a difference ... not much, but it's a way to trouble-shoot the install before you even get started with tuning ... if somebody comes up with - like 1V off of what it's supposed to be, I recon it's time to check the cabling ... Maybe though one should use the output that's supposed to be used later for the EFI input be set to a fixed value, that way any variances on the side of the LC-1 can be outruled ...
  1. Another lc1 question.. afr doesn't match on v2
    By picnic_george in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2010, 07:47 AM
  2. Car Doesnt Like To Idle
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 31st, 2008, 08:43 AM
  3. vin miss match
    By 69camaro5speed in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 3rd, 2007, 01:37 PM
  4. Main VE doesn't match MAP.SAE
    By LSs1Power in forum General (Petrol, Gas, Ethanol)
    Last Post: January 3rd, 2007, 03:11 PM
  5. Main VE doesn't match MAP.SAE
    By LSs1Power in forum FlashScan V2
    Last Post: January 3rd, 2007, 08:30 AM
