Results 1 to 5 of 5
Thread: Need help with 94 2.0L Sunbird
    Aug 2006
    Default Need help with 94 2.0L Sunbird
    Hi,
    Ive got a 1994 Sunbird. Ive bought the OBD1 cable and have had some success getting it to connect to the ECM with EFILIVE v4.
    However there are no "pre-made" vehicle definitions for my car. I am interested in creating my own, but need help with the first initial steps.
    The car is a 2.0L VIN:H
    Any suggestions where to start?
    Aug 2006
    Default 1994 Sunbird -- UPDATE
    Hi,
    I captured some of the ALDL data if it helps.
    1994 Pontiac Sunbird LE 2.0L SOHC DIS MPFI 5 speed
    34:53.079: Initialising...
    34:53.127: Opening COM1 8228,8,N,1
    34:53.182: Ready.
    35:02.913: Opening COM1 8228,8,N,1
    35:36.645: Updating vehicle information...
    35:36.660: Opening COM1 8228,8,N,1
    35:40.101: Scan for chatter...
    35:40.101: Waiting for Aldl bus silence of at least 50ms...
    35:40.151: Start reading frame
    37:37.567: Start reading frame
    37:37.672: Aldl frame header byte: $F0
    37:37.672: Aldl frame length byte: $56
    37:37.672: Recv: $F0,$56,$F4,$C6
    37:37.672: Finished reading frame
    37:37.672: (37:37.672)$F0,$56,$F4,$C6
    37:37.683: Start reading frame
    37:37.737: Aldl frame header byte: $ A
    37:37.737: Aldl frame length byte: $58
    37:37.737: Recv: $0A,$58,$00,$00,$3C,$62
    37:37.737: Finished reading frame
    37:37.737: (37:37.737)$0A,$58,$00,$00,$3C,$62
    37:37.747: Start reading frame
    37:37.797: Aldl frame header byte: $F0
    37:37.798: Aldl frame length byte: $56
    37:37.798: Recv: $F0,$56,$F4,$C6
    37:37.798: Finished reading frame
    37:37.798: (37:37.797)$F0,$56,$F4,$C6
    37:37.808: Start reading frame
    37:37.862: Aldl frame header byte: $ A
    37:37.862: Aldl frame length byte: $58
    37:37.862: Recv: $0A,$58,$00,$00,$3C,$62
    37:37.862: Finished reading frame
    37:37.862: (37:37.862)$0A,$58,$00,$00,$3C,$62
    37:37.872: Start reading frame
    37:37.922: Aldl frame header byte: $F0
    37:37.922: Aldl frame length byte: $56
    37:37.922: Recv: $F0,$56,$F4,$C6
    37:37.922: Finished reading frame
    37:37.922: (37:37.922)$F0,$56,$F4,$C6
    37:37.933: Start reading frame
    37:37.987: Aldl frame header byte: $ A
    37:37.987: Aldl frame length byte: $58
    37:37.987: Recv: $0A,$58,$40,$00,$3C,$22
    37:37.987: Finished reading frame
    37:37.987: (37:37.987)$0A,$58,$40,$00,$3C,$22
    37:37.998: Start reading frame
    37:38.047: Aldl frame header byte: $F0
    37:38.047: Aldl frame length byte: $56
    37:38.047: Recv: $F0,$56,$F4,$C6
    37:38.047: Finished reading frame
    37:38.048: (37:38.047)$F0,$56,$F4,$C6
    37:38.057: Start reading frame
    37:38.112: Aldl frame header byte: $ A
    37:38.112: Aldl frame length byte: $58
    37:38.112: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.112: Finished reading frame
    37:38.112: (37:38.112)$0A,$58,$40,$00,$3C,$22
    37:38.123: Start reading frame
    37:38.172: Aldl frame header byte: $F0
    37:38.172: Aldl frame length byte: $56
    37:38.172: Recv: $F0,$56,$F4,$C6
    37:38.172: Finished reading frame
    37:38.172: (37:38.172)$F0,$56,$F4,$C6
    37:38.182: Start reading frame
    37:38.237: Aldl frame header byte: $ A
    37:38.237: Aldl frame length byte: $58
    37:38.237: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.237: Finished reading frame
    37:38.237: (37:38.237)$0A,$58,$40,$00,$3C,$22
    37:38.247: Start reading frame
    37:38.297: Aldl frame header byte: $F0
    37:38.297: Aldl frame length byte: $56
    37:38.297: Recv: $F0,$56,$F4,$C6
    37:38.297: Finished reading frame
    37:38.297: (37:38.297)$F0,$56,$F4,$C6
    37:38.308: Start reading frame
    37:38.362: Aldl frame header byte: $ A
    37:38.362: Aldl frame length byte: $58
    37:38.362: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.362: Finished reading frame
    37:38.362: (37:38.362)$0A,$58,$40,$00,$3C,$22
    37:38.372: Start reading frame
    37:38.422: Aldl frame header byte: $F0
    37:38.422: Aldl frame length byte: $56
    37:38.422: Recv: $F0,$56,$F4,$C6
    37:38.422: Finished reading frame
    37:38.422: (37:38.422)$F0,$56,$F4,$C6
    37:38.433: Start reading frame
    37:38.487: Aldl frame header byte: $ A
    37:38.487: Aldl frame length byte: $58
    37:38.487: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.487: Finished reading frame
    37:38.487: (37:38.487)$0A,$58,$40,$00,$3C,$22
    37:38.498: Start reading frame
    37:38.547: Aldl frame header byte: $F0
    37:38.547: Aldl frame length byte: $56
    37:38.547: Recv: $F0,$56,$F4,$C6
    37:38.547: Finished reading frame
    37:38.547: (37:38.547)$F0,$56,$F4,$C6
    37:38.557: Start reading frame
    37:38.612: Aldl frame header byte: $ A
    37:38.612: Aldl frame length byte: $58
    37:38.612: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.612: Finished reading frame
    37:38.612: (37:38.612)$0A,$58,$40,$00,$3C,$22
    37:38.622: Start reading frame
    37:38.672: Aldl frame header byte: $F0
    37:38.672: Aldl frame length byte: $56
    37:38.672: Recv: $F0,$56,$F4,$C6
    37:38.672: Finished reading frame
    37:38.672: (37:38.672)$F0,$56,$F4,$C6
    37:38.682: Start reading frame
    37:38.737: Aldl frame header byte: $ A
    37:38.737: Aldl frame length byte: $58
    37:38.737: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.737: Finished reading frame
    37:38.737: (37:38.737)$0A,$58,$40,$00,$3C,$22
    37:38.747: Start reading frame
    37:38.797: Aldl frame header byte: $F0
    37:38.797: Aldl frame length byte: $56
    37:38.797: Recv: $F0,$56,$F4,$C6
    37:38.797: Finished reading frame
    37:38.797: (37:38.797)$F0,$56,$F4,$C6
    37:38.808: Start reading frame
    37:38.862: Aldl frame header byte: $ A
    37:38.862: Aldl frame length byte: $58
    37:38.862: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.862: Finished reading frame
    37:38.862: (37:38.862)$0A,$58,$40,$00,$3C,$22
    37:38.873: Start reading frame
    37:38.922: Aldl frame header byte: $F0
    37:38.922: Aldl frame length byte: $56
    37:38.922: Recv: $F0,$56,$F4,$C6
    37:38.922: Finished reading frame
    37:38.922: (37:38.922)$F0,$56,$F4,$C6
    37:38.932: Start reading frame
    37:38.987: Aldl frame header byte: $ A
    37:38.987: Aldl frame length byte: $58
    37:38.987: Recv: $0A,$58,$40,$00,$3C,$22
    37:38.987: Finished reading frame
    37:38.987: (37:38.987)$0A,$58,$40,$00,$3C,$22
    37:38.996: Start reading frame
    37:39.047: Aldl frame header byte: $F0
    37:39.047: Aldl frame length byte: $56
    37:39.047: Recv: $F0,$56,$F4,$C6
    37:39.047: Finished reading frame
    37:39.047: (37:39.047)$F0,$56,$F4,$C6
    37:39.057: Start reading frame
    Hi spirittrapper,
    I pm'd Paul to be sure he would see your question.
    Cheers
    Joe
    Hi Sprittrapper,
    Email Sent.
    Aug 2006
    Default WOW. Thanks are in order here!
    Hi,
    First off, Paul, THANKS! This is EXACTLY what i was looking for. Your my new god. LOL.
    Ive inputed most of the datastream info but im having trouble with a couple of the "equations" and getting some of the dash data to work. Its only day 2 though.
    THANKS again!!!!!
    Shawn aka spirittrapper
    www.cardomain.com/id/spirittrapper
