Results 21 to 30 of 34
Thread: No interface cable found
  1. #21
    Sep 2006
    Well I had the old scan only with the serial connection and it worked fine which is really wierd.
    My truck is a 2003 Chev Silverado SS w/ 6.0. I' m not sure of the operating system. I saw it the other day I can't remember where and I'm not connected to the truck right now though.
    I haven't tried reading the tune with the tune tool yet. It's a tuned PCM from PCMforLess.
  2. #22
    Oct 2004
    OK. So the truck should be fine, supported by the fact you have used the Scan Tool with what I guess was an AutoTap cable?
    I'll send a link to this thread to the other Mods and see what we can get going for ya.
    Andrew
    EFILive Crew
  3. #23
    Oct 2004
    PM sent to the other moderators, and I also included Paul/Ross. Paul and Ross are hidden away working feverishly on the LS2 stuff, but hopefully some more fresh eyes on the job will have you working soon.
    Andrew
    EFILive Crew
  4. #24
    Sep 2006
    Yeah I used it with an autotap cable. The scan software I bought used from someone on another site. Since the guy I bought it from already upgraded to FlashScan, I just purchased a brand new personal flashscan (not upgrade) with the new cable and everything.
    Thanks Tordne, this is getting really frustrating.
  5. #25
    Foxy,
    We need you to do the following with your V1 cable connected to your vehicle...
    We need you to post screenshots of the following:
    a. Help->Register EFILive from Scan Tool
    b. Help->Register EFILive from Tune Tool
    c. Help->FlashScan PCM Licensing
    Click on the connect button in the scan tool;
    on the Console tab in the Scan Tool, do:
    click inside text area,
    Ctrl-A (highlights all the text),
    right-click and copy,
    paste into Notepad.exe,
    save to file,
    attach this file to your reply.
    Joe
  6. #26
    Sep 2006
    Okay, will do. Not quite sure how to take screenshots though.
  7. #27
    Quote Originally Posted by foxySS
    Can do this: showthread.php?t=3064
    If you don't want to host your image, you can upload it directly to the forum by pressing the Manage Attachments (may have to press Go Advanced first) in your reply (press Browse, find image, and press Upload, then finish your reply).
  8. #28
    Sep 2006
    Okay, here they are:
    and here's the copy of the console log:
    21:07:25.765: EFILive V7 Version V7.3.2 (Build 416)
    21:07:27.687: Ready.
    21:08:22.484: Scanning for EFILive FlashScan Cable (USB)
    21:08:22.500: Autodetect interface ...
    21:08:22.593: Connection to [FSP] interface is OK
    21:08:22.625: Autodetect OBD II protocol...
    21:08:22.671: Connection to vehicle is OK
    21:08:22.703: Interface firmware model: FSP
    21:08:22.718: Interface firmware version: 1.2.17
    21:08:22.750: Interface firmware date: Jan 18, 2005
    21:08:22.765: FlashScan serial number: 003574xxxxxx
    21:08:22.843: Request GM VIN...
    21:08:22.968: VIN: 2GCEK19N031xxxxxx
    21:08:22.968: Request serial number...
    21:08:23.093: Serial number: 0KA009X83176
    21:08:23.093: Request hardware nubner...
    21:08:23.140: Hardware: 12583659
    21:08:23.140: Request GM operating system...
    21:08:23.187: GM operating system: 12593058
    21:08:23.187: Request GM NVM...
    21:08:23.234: GM NVM: 12586860
    21:08:23.250: Request GM Engine calibration...
    21:08:23.281: Request GM Engine diagnostics...
    21:08:23.343: Request GM Transmission calibration...
    21:08:23.390: Request GM Transmission diagnostics...
    21:08:23.421: Request GM Fuel system...
    21:08:23.468: Request GM System...
    21:08:23.531: Request GM Speedometer...
    21:08:23.578: Request GM BCC...
    21:08:23.609: GM BCC: YFRC
    21:08:23.625: Request GM VAT Cycles...
    21:08:23.656: GM VAT cycles: 0
    21:08:23.671: Request GM oil life...
    21:08:23.703: Oil life: 23
    21:08:23.718: Query support for stream.01 scan mode...
    21:08:23.890: Query support for stream.02 scan mode...
    21:08:24.109: Calculating number of dynamic packet ID's...
    21:08:25.031: Loading generic configuration file: sae_generic.txt
    21:08:25.031: User defined calculated PIDs file: calc_pids.txt
    21:08:25.046: Enhanced configuration file: gm_enhanced.prn
    21:08:25.484: Request GM VIN...
    21:08:25.609: VIN: 2GCEK19N031xxxxxx
    21:08:25.609: Request GM operating system...
    21:08:25.656: GM operating system: 12593058
    21:08:25.687: Validating PIDs...
    21:08:25.875: Validating Modules...
    21:08:25.906: Initialising PIDs...
    21:08:26.062: Initialising Modules...
    21:08:26.078: Ready.
    Last edited by joecar; September 3rd, 2006 at 04:53 PM. Reason: Removed screenshots showing license keys and privatized the VIN
  9. #29
    Ok, I saw your screenshots, they look ok...
    I removed them because they contained you s/w license key (sorry, my bad, I should have ask you to blot out a portion of the license key... )
    The Tune Tool PCM license window shows that the Tune Tool can read the serial number from the FlashScan (and it shows you still have 2 unused PCM licenses).
    The console log shows successful comms between FlashScan and PCM.
    So now it's working... right...?
  10. #30
    Sep 2006
    That's the wierd thing. It looks like it's connected but when I go into the dashboard or try and look at the PID's they aren't doing anything. That's when I have the monitor button pressed as well.
    Then when I go to refresh system results and a few other things I tried (I can't remember which,) it usually says no cable and it keeps trying to reconnect. Every time it's unsucessful. I don't know.
  1. V2 "No interface cable found"????? Why??
    Last Post: August 5th, 2008, 12:13 PM
  2. What module to get EFILive V1 Interface Cable Or?
    By JETNITRO in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 09:07 AM
  3. No interface cable message
    By LS1WV in forum General
    Last Post: February 17th, 2006, 12:17 AM
  4. Sudden "No Interface Cable Found" problem
    By mtnman in forum General
    Last Post: November 22nd, 2005, 05:26 PM
  5. No interface cable found
    By eboggs_jkvl in forum General
    Last Post: November 21st, 2005, 05:09 PM
