Page 1 of 9 123 ... LastLast
Results 1 to 10 of 89
Thread: Shift Light in 2k F-Body?
    Jun 2006
    Default Shift Light in 2k F-Body?
    Just seen the Shift Light options ... does that mean I can hook up a line directly to the PCM and control the RPM via EFIlive config?
    If so, what settings are good (I usually shift around 5500-5700) and what technical specs are there to hook something up?
    Jun 2006
    Hm .. nobody?
    Description in EFILive is:
    Enable the PCM shift light output (J2,pin47), if not then send message to upshift on data bus if {B5814} "(not available in this operating system)" is enabled.
    (entry B5817)
    So, if I hook up a cable to this pin, do I get a logic "high" (12V?) when the light is to be lit?
    Read up at different places, seems like the output is used on the A4:
    47 YEL/BLK 1223 Transmission Shift Solenoid B
    Jan 2005
    i think it may be applicable in the camaro or any other car that has a shit light
    Jun 2006
    I haven't seen any stock shift light in a Camaro or Firebird yet ... but if the PCM has it, I figure it should be possible to add ... I guess I might check it out sometime ... maybe next weekend ... anything to watch out for when disassembling the PCM assembly?
    Oct 2004
    There is a shift light used in some HSV (Holden) vehicles. I'd be interested in this aslo
    Andrew
    EFILive Crew
    Jun 2006
    hm ... I checked some of the HSV files on HoldenCrazy, but none seemed to have any settings for shift lights included ... !?
    Oct 2004
    2004 HSV GTS Manual
    Andrew
    EFILive Crew
    Jun 2006
    Tnx!
    Guess I'll just check out that pin first and see if it is working as expected in my 2k ... good to have some reference as to values to enter in the tables afterwards ...
    Oct 2004
    Let me know what you find mate. I'd be real keen to wire one into the PCM as well!!!
    Andrew
    EFILive Crew
    Jan 2005
    Anyone know what US bound LS1 based vehicles actually had the light? I can look up the PCM pin out for you.
  1. Shift Light
    By BRD-PREY in forum General (Petrol, Gas, Ethanol)
    Last Post: January 13th, 2009, 10:16 AM
  2. 04 GTO Shift Light
    By jpalamar in forum Gen III V8 Specific
    Last Post: December 5th, 2008, 03:04 AM
  3. Shift light?
    By traumadog in forum Gen III V8 Specific
    Last Post: December 4th, 2008, 07:10 AM
  4. Using the pcm controlled shift light
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2008, 05:56 AM
  5. shift light
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 17th, 2006, 06:07 AM
