Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 89
Thread: Shift Light in 2k F-Body?
  1. #21
    Oct 2004
    Quote Originally Posted by ringram
    Tordne, I hope if you get it fitted you set the, to quote TAQuickness, "shit light", higher than 3000 rpm
    You hassling my nana driving mate
    Andrew
    EFILive Crew
  2. #22
    Jul 2004
    Quote Originally Posted by Garry
    I tried ... not big enough to keep it from pushing in ... don't think it connected correctly, or either the PCM didn't put out a signal on it, as I tried to measure it, and couldn't get anything (had the RPM set to 1200, and measured it against ground)
    It might be open collector, try connecting a 1K resistor between 5V and that pin and see if it moves then. If you can't find 5V, try 3 1K resistors in series, one end to 12V, one end to ground and then connect the pin to the other end of the resistor connected to ground. It should measure 4 to 5 Volts, check before hooking it up as you don't want to connect it to the 8V side just yet.
    Ira
  3. #23
    Jun 2006
    I remember seeing some 5V reference voltages for different things on several PCM pins - I recon it's not a good idea to use them ...
  4. #24
    Jun 2006
    Finally found the right type of connectors like the ones that go into the PCM plug ... made for BMW e.g. ...
    ... only they are too big, inside .5mm and up, outside is 2.1mm ... I recon I need something like .25mm and up inside diameter, outside diameter something like 1-1.5mm ... oh well, at least I can check with car places around and show them what I am looking for without taking the car and disassembling it to show them
  5. #25
    Oct 2004
    I think ringram' used the jumper from a PC motherboard, like the HDD light connector. Might be worth a look?
    Andrew
    EFILive Crew
  6. #26
    Jun 2006
    I know. I tried that, and other stuff I had, and nothing I tried worked out reliably. Mainly, they were to short to stay in the plug right ... or too big to fit in the plug ... or too big a hole to make contact to the rather thin PCM pins ... :(
  7. #27
    Do you mean adding a pin to the PCM plug (that plugs into the PCM)...?
    Someone like Ira or Caspars Electronics might have the appropriate terminals/pins and tools/picks...
    Did I understand correctly...?
  8. #28
    Jun 2006
    yes ... them pins ... problem is finding the right part if you don't know its "real" name ...
  9. #29
    Member ace68's Avatar
    Jun 2004
    http://www.eficonnection.com/eficonn...t.aspx?vi=true
    try this place or the connectors they are on vacation this week but they were answering the email. They don't list everything they carry so if you don't see what you want email them what you need and they may be able to help you out.
  10. #30
    Jun 2006
    Whoa ... getting these Pins is a major PITA ... I finally found the "original" parts, they're Delphi "Micro-Pack" connectors, sealed version, Delphi/Packard part# seems to be 12084913 ... (or 12084912 for 0.8mm^2 cable)
    Now to the even harder part ... getting some
  1. Shift Light
    By BRD-PREY in forum General (Petrol, Gas, Ethanol)
    Last Post: January 13th, 2009, 10:16 AM
  2. 04 GTO Shift Light
    By jpalamar in forum Gen III V8 Specific
    Last Post: December 5th, 2008, 03:04 AM
  3. Shift light?
    By traumadog in forum Gen III V8 Specific
    Last Post: December 4th, 2008, 07:10 AM
  4. Using the pcm controlled shift light
    By Chris81 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2008, 05:56 AM
  5. shift light
    By RUTAN TA in forum General (Petrol, Gas, Ethanol)
    Last Post: July 17th, 2006, 06:07 AM
