Results 1 to 3 of 3
Thread: tuning -newbie
    Dec 2005
    Default tuning -newbie
    on a 2000 5.3 what can I tune with out a wideband 02? can the stock 02 be used for any type of fuel/air tuning?
    Jan 2004
    You can try and get the ve table dialed in for normal cruise, but many have seen problems from that when going to a wideband. It doesn't reflect the correct values and is off. Best bet is to invest in a wideband.
    Jun 2005
    I used the STFTs to dial in part throttle tuning on my stock internals '02 Z28 and my friend's cam'd T/A. As long as there are no exhaust leaks and the stock O2's are active, it should be fine using them everywhere PE doesn't kick in. I'd still leave PE active, DFCO active and all that fun stuff since you can filter it out in the log. The only thing I would turn off (if they're withing +/- 10%) is LTFT's and the MAF (if you want to adjust VE - don't forget to copy high spark to low). Then, you can take the average of the STFT's recorded and adjust either the VE or the MAF - which ever one you're working on at the time.
  1. newbie and wanting to get into ls1 tuning
    By savo in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 07:17 PM
  2. Newbie Question: connection and "tuning"
    By Player87 in forum Gen III V8 Specific
    Last Post: February 5th, 2009, 05:20 AM
  3. Newbie???'s
    By bdr2008 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 11th, 2008, 04:46 AM
  4. Hi Newbie
    By vxleather in forum General (Petrol, Gas, Ethanol)
    Last Post: February 14th, 2008, 09:15 AM
  5. Newbie tuning a camaro
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 8th, 2007, 03:30 PM
