It's really weird, Windows XP safe mode comes up, can access quite a few files ok, other files hang Windows Explorer, disk repair thrashes itself to death trying to repair half the disk (250GB SATA disk).
Sounds like a fairly new drive? Can you install it as a secondary via USB or something to try and save files?
Or, are you only as good as your last backup?
PowrMax Performance
100 mm PowrMAF
Glad to hear ... symptons point towards some untimely end for the drive, so get off of it as much as you can (and need), then send it in for warranty replacement ... (I recon) If Windows fails to work on the drive at all, try to boot off of one of the Linux System-Repair CDs, they usually give you most of the tools you need to save as much as possible ...
Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
WinXP boots in safe mode, and I read all the important files, now I just have to get the unimportant/convenient ones.
Have you tried to boot from the windows installation disk to do a windows repair or tried windows recovery?
Regards,
Neil.
Neil,
Disk repair started up and mentioned a whole bunch of bad/unreadable blocks, but I'll give the windows repair a try, maybe there are enough useable blocks on my 250GB disk.
Thanks,
Joe
Joe,
You might want to take a look at SpinRite by Gibson Research (www.grc.com). That program is specifically designed to operate on disks at the sector level.
Regards,
Dick
Show me a man who knows all the answers and I'll show you a man who is not aware of all the questions.
Dick,
Ok thanks, I'll give them a try (I have edited DOS FAT file headers before... ).
Edit: I have been to GRC before, that's where "Shields Up" is...
Joe
