Results 1 to 8 of 8
Thread: Question on LC1 with V2 and TA cable...
    Jun 2005
    Default Question on LC1 with V2 and TA cable...
    I have not used my wideband in about 2 years since I was running V1.
    Question is... I have my V2 all ready to go but need to know what wires on my LC1 I hook up and to where, What changes since I bought the T/A cable that plugs into the LC1 (OUT).
    Do I still run:
    - red to switched power
    -blue to chassis ground
    Do I still have to use the white, green, yellow and brown wires?
    THANKS FOR ANY HELP!
    '71 chevelle
    Twin turbo ls1
    1000 HP 93 octane street car!
    96 lb injectors
    Nov 2006
    Al the serial cable does is transfer data, it still needs 12v & ground.
    Connect the white wire to chassis ground.
    You don't need to have the analog wires connected to the V2.
    LC-1 WBO2
    Jun 2005
    So blue and white go to chassis ground, red to switched ignition, and then I am good to go?
    No other wires need to be connected except for the TA cable from the wide band to the V2 then then?
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    Nov 2006
    Don't forget to connect the serial cable to the V2.
    FYI the white wire (system ground) emits +/-1v.
    If using the LC-1 to simulate a NBO2 then it would go back to the PCM for the Low Signal and
    the analog wire that is programmed to simulate NBO2 goes to the High Signal.
    LC-1 WBO2
    Jun 2005
    Im not using as a narrow band. So the white wire... I have it connected to chassis ground, is that wrong/. Does it have to go to the V2 A1-??
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    You can leave the white wire disconnected...
    When you use serial comm, you don't need any connections to AD[1-4]-.
    Jun 2005
    Lol,
    O.K. then, I hook up blue to ground, red to power, make sure the serial cable is connected between the LC1 and the V2 and then I'm set!
    Sounds to simple...
    '71 chevelle
    Twin turbo ls1
    96 lb injectors
    You have to go into the V2 setup options and tell it the brand of wideband...
    see TA's tutorial: showthread.php?t=8858
  1. Need new OBD cable for V2
    By Beer99C5 in forum FlashScan V2
    Last Post: January 22nd, 2010, 01:36 PM
  2. USB Cable Question
    By Duramax 6.6L in forum FlashScan V2
    Last Post: July 13th, 2008, 12:00 AM
  3. why do I have a com cable and what to do now?
    By C5Vette in forum FlashScan V2
    Last Post: July 4th, 2008, 11:14 AM
  4. Cable Question
    By austintr in forum General
    Last Post: January 31st, 2006, 01:36 PM
  5. Cable
    By Stingray in forum General
    Last Post: August 20th, 2005, 01:04 PM
