Thread: "PCM is in an Unkown State" & "Reflash Failed"
    Sep 2006
    Default "PCM is in an Unkown State" & "Reflash Failed"
    I just tried reflashing my PCM and at the end of the process it says "pcm is in an unknown state," and "reflash failed." I tried reflashing twice and in between each time I tried closing and reopening the reflash window as suggested on one of the forum threads. Still won't work. Now the truck won't start up.
    Any ideas or suggestions?
    Unknown Zone TAQuickness's Avatar
    Jan 2005
    Were you trying to load a custom operating system or full flash or just a calibration only flash?
    Sep 2006
    Just a calibration flash
    Turn ignition OFF.
    Find the PCM BATT fuse, and pull it out for a minute or so, and then reinsert it.
    PCM should now be okay.
    Sep 2006
    Well, I got it to work. Not sure what solved the problem as I tried multiple solutions at once. I pulled the PCM1 fuse, the PCM B fuse for a minute and put back in. I also pulled the RADIO and RADIO BATT fuse and left them out while I reflashed. In the flash window I also turned High Speed off.
    Justin (I'm not sure of his member name on here, . justin . or DC Justin) has helped me out a lot with fixing my crappy tune that I had in there and also gave me some help as to issues with the reflash. We both have almost the same setup. Thanks Justin! And, thanks to all you guys who have helped me out thus far.
    Chris
    Aug 2005
    Let me know how the tune works out.
    2013 Yukon Denali XL - TVS2300, ID1000, E85
    2013 Silverado CCSB 6.2L - TVS1900, DTH 349Y-1-C
    1972 K5 Blazer - LQ4, TVS2300, 4L80E
  1. "A call to an OS function failed"
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: August 14th, 2009, 09:46 AM
  2. what table controls start up decay speed? "how fast it decays out"
    Last Post: March 20th, 2009, 12:10 AM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. "REFLASH" Recall on 07 LMM
    By ssvolvo in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 15th, 2008, 03:06 AM
