Can't find a stock version of this OS. If anyone has it, please email to superls1@yahoo.com
Thanks.
Thanks.
If you get it can you please send on to me so I can add it to the repository?
Andrew
EFILive Crew
Will do, but no luck so far. :(Originally Posted by Tordne
99 Vette - coupe, 6 speed.
I found a stock version in HPT format.
If you found it in a .bin format, just open EFI Live, then click File>Open, go to the .bin file and open it. Then, click File>Save tuning file as... and you can save it as a .tun file. If it's an .hpt file, find someone with HPT tuners to save it as a .bin file and then follow the steps above. Someone over at LS1tech.com might be able to help you with that if needed.
I have an EFILive .tun file and a HPTuner .bin file for a 1999 Corvette M6, but the OS for both of them is 09373372.
If you can use them, let me know and I will email them.
I have 09373372...which is 99 vette 6 speed coupe.
1999 C5. ATI procharger, Alky injection, 228/232, .595/.598 on a 114lsa, 317 heads, Full exhaust no cats.
