Results 1 to 4 of 4
Thread: Higher Wattage O2 Sensor Part #?
    Apr 2005
    Default Higher Wattage O2 Sensor Part #?
    At one point, I had this info. Generally, I was under the impression the vette rear O2's were higher wattage. Therefore, they were less susceptible to the switching error codes (P1133/53, etc). However, I was told today that some of the vette years had lower wattage O2 sensors in the rear location.
    So, I want to ensure that I buy the higher wattage ones. Anybody know for certain the part number?
    Jun 2005
    Denso 234-4617
    NGK 21537
    Bosch 13111
    AC Delco 25317697
    Apr 2005
    Thanks. I swear I had the Bosch number written down, but I simply couldn't find it.
    Are there any issues with the connectors? Square vs flat?
    Jun 2005
    Those should all be direct replacements according to gmpartsdirect.com and sparkplugs.com.
  1. need part# for lm1 sensor
    By minytrker in forum General
    Last Post: August 5th, 2009, 05:41 AM
  2. What happens when I set a value higher than the tables know?
    Last Post: August 1st, 2009, 02:32 AM
  3. more air = higher compression?
    By jchev502 in forum Vortec V6/V8 Specific
    Last Post: July 19th, 2008, 09:21 AM
  4. Turning EGR Off Higher EGT's?
    By petestoy in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 21st, 2008, 11:26 AM
  5. Map Sensor Part#'s
    By ForcedC5 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 13th, 2006, 09:59 PM
