Results 1 to 10 of 11
Thread: Did I kill PCM; Advise Please
    Sep 2004
    Default Did I kill PCM; Advise Please
    My plan was to load the stock .tun file for my 1998 Corvette 6sp.. After verifying my operating system was a *****200 type, using the Scan Tool, I downloaded 19980200 file from Holdencrazy.com. I loaded .tun file into EFILive Tune, then mistakenly selected "Program PCM with currently loaded operating system and calibration" instead of "Program PCM with currently loaded calibration". I saw program communicate with PCM, it completed erase PCM cycle, but never started loading any program. It kept saying something, but I can't remember; it was something like retry.
    Currently when I try to load either the Calibration or Operating System, EFILive says. "Preparing PCM for reflash", then next line says "PCM may not be secured - did not reply to seed request" It goes through four retry's then gets a "Bootloader rejected" error. "Reason: No response from PCM"
    Mistake was mine for selecting to load Operating System and .tun file. I really only wanted the .tun file. Any idea's? Thank you in advance
    \'04 Z16 Corvette, AFR 205 heads, Comp 228/232 114+4 LSA custom cam, HS Rockers, Kooks 1 7/8\' headers, 3\" X-pipe, stock Ti tail section. \'98 Corvette Pace Car, \'04 Chevy Avalanche Z71 4X4.
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Do you have the Personal or Commercial version of EFILive?
    Do you have a saved copy of the file that was previously in your PCM prior to this hiccup? If so and you have the Commercial version, use that file to "Program PCM with currently load operating system and calibration" to restore your PCM.
    Someone may have some other ideas to try. Worst case, send the PCM to me along with the "original" file and I'll bench-flash it for you.
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Sep 2004
    Thank you. I have the commercial version. I do not have the orignal Operating System file. I only have the orignal .tun file. So does it sound like I killed it?
    Sep 2003
    The "original" .tun file, is it the one that was in the PCM before the Holdencrazy version?
    If so, have you tried to do a full flash?
    Sep 2004
    I had a very close to orignal .tun loaded in. But I loaded it some time ago. I loaded in my orignal .tun a couple weeks ago, but felt it was actually a modified version. So that is why I down loaded the stock .tun from Holdencrazy.
    Currently PCM doesn't seem to accept any .tun, or Operating System. Just gives me the messages listed above. Thank you for your information, I've just got this feeling somehow I've put my PCM to sleep. It basically will not respond to communication.
    Oct 2005
    The common next step is to pull the pcm fuse or battery for a few minutes. Then try again with a full reflash.
    Ask joecar how he knows this..
    2014 VF SV LS3 Maloo.
    Sep 2004
    I unhooked neg side of battery for about 15mins, still same results. I'll try pulling the fuse for PCM. I suspect both will be same result, but hey I'll try.
    Thank you for the idea's
    Quote Originally Posted by ringram
    Yes, I got the same messages and a few others, and I not could flash, car would not start right away, but after 15 minutes it started up (I knew that the flash had not been written, so it should run ok), I logged spark, afr, wb afr, they all seemed to be correct, but I still could not flash; cycled the PCM BATT fuse,and then every thing was fine.
    May want to do several key on key off cycles.
    Aug 2005
    The thing that concerns me is that your message says that the memory was erased, but the inital 16-32K of communication data was never flashed in... That's the only "red light" portion of the process, and it sounds like it may have failed at that point...
    Quote Originally Posted by dc_justin
    If that's what happened, then the flashing routine may not be present, which means the PCM would be incapable of flashing and is quite dead ; but I hope I'm wrong.
  1. AutoVE Best Power Advise
    By Rusty in forum Gen III V8 Specific
    Last Post: January 19th, 2009, 04:52 PM
  2. Advise required by newbie
    By SA1 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 7th, 2007, 12:10 AM
  3. cal_link advise
    By mr.prick in forum RoadRunner Real-Time PCM Emulator
    Last Post: November 1st, 2007, 02:58 PM
  4. Good Kill
    By TAQuickness in forum Lounge
    Last Post: September 25th, 2006, 06:34 AM
