Results 1 to 10 of 19
Thread: cylair formula's units
    Jul 2005
    Default cylair formula's units
    This is what I found in the little explanation/help window on VE table:
    The air mass per cylinder can be determined from the VE table using the following formula:
    g/cyl = VE*MAP/charge temperature
    Ve is in g*K/kPa,
    MAP is in kPa,
    and then in the temp blend explanations i found:
    273.15+IAT+((ECT-IAT)*factor) with the factor of 0.042969 for any significant airflow.
    so with VE of 100 g*K/kPa,
    MAP of 100kPa, and
    IAT of 82F and ECT of 190F
    so i tried to see if it works so i did:
    airmass= 100*100/303=32.9 g
    that ain't right, so i thought maybe the VE should be as % so:
    airmass= 1 * 100/303=0.329g which is too low for a WOT condition on a typical engine.
    what am i doing wrong?
    thanks,
    Marcin
    Jun 2005
    Did you convert to *C before the *K calculation?
    Jun 2005
    **Edit** I just noticed that your VE listed in your first post is 100. That means it's 100% of the theoretical maximum (based on cylinder volumes I believe). You need to go to Edit>Properties and change the VE drop-down menu to Grams*K/kPa and reload your file. See below for mathematical explanation.
    Double check your math and make sure your VE is in Grams*Kelvin/kPa units under edit>properties. I just checked mine where I usually record ~.80(grams/cyl) in my logs. Using your temps converted to Celcius, I get a charge temperature of 303.50591(K). At 100kPa on my VE table, I have 2.4365(Grams*Kelvin/kPa) at 4400(RPM), which is where I see most of my airflow with the stock cam (peak torque).
    If I take 2.4365(Grams*Kelvin/kPa)*100(kPa) and divide that by 303.50591(K), I get 0.80278 (grams).
    Jun 2005
    TTT for the edit above...
    Yes, I agree, VE ranges somewhere in the vicinity of 2.0 g.K/kPa (+/- some amount)...
    100 g.K/kPa seems way too high...
    Jul 2005
    oh yea, good catch...thanks guys.
    so how do we arrive at the % theoretical? is that what the unit HPT displays too?
    Jun 2005
    I'm pretty sure that's what HPT shows. PM Blacky...he might be able to hook you up with the equation for VE% based on theoretical maximum.
    http://forum.efilive.com/member.php?u=4
    Jul 2005
    eh, no need, i figured it out, thanks guys
    Quote Originally Posted by redhardsupra
    RHS,
    Did you calculate the mass of a cylinder volume's worth of air and compare with VE table cell(s), is that what you did to get VE% of theoretical max...?
    Joe
  1. Formula help for Calculated Pid
    By vetteboy2k in forum Black Box Logging
    Last Post: December 21st, 2012, 10:16 PM
  2. Should CYLAIR = DYNCYLAIR?????
    By BlackGMC in forum Gen III V8 Specific
    Last Post: November 2nd, 2008, 01:49 PM
  3. MAF Calibration..Why not use SAE MAF vs CYLAIR DMA
    By WeathermanShawn in forum Gen III V8 Specific
    Last Post: September 30th, 2008, 10:44 PM
  4. Run Spark Formula
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: March 24th, 2008, 02:07 AM
  5. Replies: 5
    Last Post: April 27th, 2005, 01:26 AM
