Results 1 to 4 of 4
Thread: Please verify...
    Jun 2005
    Default Please verify...
    Values entered into {B3641} PE Mod. Based on IAT are subtracted from commanded EQ Ratio. In other words, if I have 1.125 EQ (13:1 AFR) commanded and I put in "-0.027" in this table, it will command an EQ of 1.125-(-0.027)=1.152 (12.7:1 AFR). Correct???
    The description is wrong in EFILive. It should say:
    When in power enrichment mode this value is added to the commanded fuel EQ Ratio.
    Jun 2005
    Gotcha....thanks! That coulda been bad news!
    Same problem in the description of B3617 (ECT).
    Both the IAT and ETC modifiers are ADDED to the PE EQRatio.
  1. Just want to verify what I belive (upgrading OS)
    By VTC_WS6 in forum Gen III V8 Specific
    Last Post: June 15th, 2008, 09:17 AM
  2. Calculated VSS (used to verify speedo calibration)
    By joecar in forum Tips and tricks
    Last Post: January 19th, 2006, 04:18 PM
