Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 53
Thread: MEFI 4 ECM definition file
  1. #41
    Oct 2005
    Yes, I have an aldl cable, but it actually seems kind of pointless at this point, I really can't do that much without the oxygen sensor input.
  2. #42
    Oct 2005
    Right now it is not possible to log ALDL data streams with FlashScan V1 or V2. That will be available once the V8 Scan Tool software is released for FlashScan V2.
    Paul, can you point me to the thread where I can get updates on the status of the software release you referenced here?
  3. #43
    Quote Originally Posted by Extinct View Post
    Each time we release a new software update (including pre-releases) we'll post it here:
    http://forum.efilive.com/forumdispla...tallation-Help
    There is a pre-release update due to be posted this week.
    It does not have ALDL support yet, but we are much closer to releasing ALDL support because ALDL uses a very similar logging strategy to the Cummins logging which is supported in this pre-release.
    And this page will get updated when each official public release is available:
    https://www.efilive.com/index.php?op...=48&Itemid=133
  4. #44
    Oct 2005
    Paul, quick question on this, my next shot at this project is in March, do you expect to have the ALDL logging by that time or should I prepare a plan b?
  5. #45
    Sorry, ALDL logging via Flashcan or AutoCal won't be available before March.
  6. #46
    Oct 2005
    Thanks for the reply Paul, that helps with my planning!
  7. #47
    Oct 2005
    Paul, thought I would check in here as I am anxious to be able to use my EFILive scanner to read the MEFI datastream with a wideband. In the interim, I went snooping around on the internet looking for alternate solutions - thought it was funny that when I looked in on the competitors forum it led right back to where I started with you.
    For your enjoyment: http://www.hptuners.com/forum/showth...highlight=aldl
  8. #48
    Oct 2005
    I was just re-reading this -are we there yet?
  9. #49
    The short answer is no.
    The long answer is I am working on the V8 scan tool right now (have been for the past few months).
    I still can't say when we'll have ALDL ready though.
  10. #50
    Mar 2016
    OK, still moving through populating all of the data fields. If you guys wouldn't mind taking a look at this example screen shot - have I left anything out that I need to populate in to the EFILive configuration (haven't started working on the dashboard or charts yet, that will come later - is that really required for the .xml file?)?Attachment 13843
    Appreciate i'm dragging up the past but could you share your definitions?
    would be greatly appreciated :-)
  1. Need definition for 16197427
    By serial_killer in forum EFILive V4
    Last Post: October 7th, 2009, 08:59 AM
  2. DSP Output definition
    By killerbee in forum General (Diesel)
    Last Post: July 5th, 2009, 03:12 PM
  3. Mercruiser MEFI ECM's (MEFI-3 in particular)
    By MichaelsTractors in forum General (Petrol, Gas, Ethanol)
    Last Post: January 24th, 2008, 06:37 PM
  4. Custom/DIY calibration definition file?
    By jimter in forum General (Diesel)
    Last Post: October 10th, 2007, 09:25 AM
  5. MEFI Controller
    By Fran D in forum General (Petrol, Gas, Ethanol)
    Last Post: August 18th, 2006, 01:54 PM
