Results 1 to 4 of 4
Thread: connecting with EFIlive
    Sep 2015
    Default connecting with EFIlive
    Hello every one
    had efilive v4 pro for about a month and still having trouble connecting to my 2001 vx 3.8 v6 ecotec
    my last try came up with ( com timout: expecting frame header byte ) I am getting very frustrated
    with this program, on the disk it says connect and diagnose in 60 seconds
    I have a program to test the aldi cable and it pass
    Does anyone in the western suburbs of Melbourne run this program on a vx, I can visit and see how it works
    at the moment I have a problem with my idle and I would like to fix it
    thanks Everyone
    Goodi
    Lifetime Member limited cv8r's Avatar
    May 2005
    Did you select the VX V6 XML file in the software?
    It's all good until it goes "Bang"
    Sep 2015
    Hello cvr8
    on the weekend I managed to connect with my ecu
    it was some settings in the timing section how ever when I connect I forgot to select vx v6 xml and it was sending and receiving data
    for a long time so I stop it I will try tomorrow when I get home
    can you tell me when I do connect how long does it take to receive all the data from the ecu
    Goodi
    May 2005
    What data are you trying to get from your ecu ? Efilive V4 is only a scan tool.
  1. need help connecting aem uego to flashscan v2 efilive
    By lsx_production in forum FlashScan V2
    Last Post: May 30th, 2016, 02:18 PM
  2. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  3. Connecting LC-1's
    By MyM8V8 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 7th, 2009, 10:21 AM
  4. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  5. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
