I've been doing some AutoVE tuning (finally) and am close to getting all the BEN's around 1. My C5 is a 2001 and has the 5 pin connector that includes IAT sensor as well. With the MAF disabled per the instructions, I was wondering if I should be concerned about whether the MAF is really disabled or not? I've read that the only way to know for sure that the MAF is disabled is to remove the connector but if I do that then I have to find another way to connect the IAT sensor. Is this really necessary or can I be reasonably assured that the MAF is fully disabled by changing the parameters as shown in the AutoVE tutorial? I did check for the DTC's for the MAF and they were there and the MIL did not illuminate.
Thanks,
