Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Fine tuning AFR in PE
    Dec 2005
    Default Fine tuning AFR in PE
    I'm commanding 11.0 and getting an actual afr of 12.4-5. Tried to lean out in the PE table from 11.0 to 11.1 and actual afr went to 13.6. That is a very big jump from adjusting .1 in PE table. Any suggestions or tips?
    Sounds like you need to get your VE and/or MAF tables corrected.
    The AutoVE Tuning tutorial is a good starting place:
    http://www.efilive.com/download.aspx#downloads7
    You will either need a wideband O2 sensor (recommended), or attempt to correct you VE table using LTFT's.
    Also see this: showpost.php?p=31617&postcount=5
    Dec 2005
    Thanks. I figured that. I was trying not to have to deal with all that mess. Downloaded a stock 6.0 lq9 file from this site and copied that VE table to my tune hoping to just run a stock VE table, but it seems that won't work.
    Lifetime Member Doc's Avatar
    Oct 2005
    Take the high road grasshopper.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jan 2005
    Quote Originally Posted by Doc
    agreed.
    Sep 2003
    Also make sure you are looking at your PE units in EQ Ratio and not lambda unless you are looking at AFR
    Larry - HumpinSS
    Dec 2005
    I skimmed through the auto ve write up and I have a couple things. My WB is not connected to efilive, would this be a problem? I'm still running the 99 pcm, and the write up does not say what to do when complete. (All things that had to be changed to get into SD)
    Jan 2005
    Will be much easier to have the WB connected to Flashscan. 99 pcm is fine. When you're done, the next steps depend on what you want to do. I stayed in OLSD, some go to CLSD, some recalibrate the MAF and go back to CL MAF.
    Otherwise, the AutoVE tutorial will have you return to CLSD.
    Dec 2005
    I don't think my AEM WB is compatible with efi live. Also, how do I return to CL MAF when done?
    Jan 2005
    if your WB has a 0-5vdc output it's compatible. Linear output makes things much easier as well.
    CLMAF - is described in the last 2 pages of the AutoVE tutorial. Depending on your mods, you may need to recalibrate your MAF. Same concept as AutoVE.
  1. 08 Silverado 5.3 Tuning, tuning-spark/pe mode/
    By hulm333 in forum Gen IV V8 Specific
    Last Post: November 16th, 2009, 04:44 PM
  2. Idles fine after loading new tune. Drive it goes to crap
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: January 16th, 2008, 02:14 PM
  3. Need a little help gettin started on COS3 fine tuning. Please
    By nonnieselman in forum Custom Operating Systems
    Last Post: June 11th, 2007, 05:47 PM
  4. RTACS fine/coursse control
    By tazinhawaii in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 8th, 2007, 11:40 AM
  5. Idles fine till I turn on AC
    By skippy in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2006, 04:02 AM
