Results 1 to 6 of 6
Thread: another newbie question
    Dec 2005
    Default another newbie question
    I have been reading about autove tuning and such. My question is why do you dialin the VE table then put the car back into closed loop??? Are the stock VE tables that far off??
    Jan 2005
    Quote Originally Posted by turbo lcc
    If the system is in closed loop, it will automatically correct the air/fuel mixture, so any logged data will be skewed. By staying in open loop, the system can't "correct" the results of any changes made to the VE table.
    DigitalEFI- EFILive US Distributor
    sales@digitalefi.com
    678/344-1590
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Autotuning allows you to tune to what you have. If you are 100% totally stock and never touched anything, then the stock VE tables are probably just fine. In my case, I have a mixed breed. I have the LS6 internals, reduced CR, and the LS1 Intake so the stock VE table probably has room for improvement. Heads & cam, stock VE has room for improvement. So, by doing the autotune, you get the VE table spot on to "your" mods and then you toss it back to closed loop and let the PCM handle it.
    At least that's how I understand the thought process.
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Lifetime Member Doc's Avatar
    Oct 2005
    Well said.
    www.efialchemy.com
    www.greatamericancarwar.com
    Dec 2005
    eboggs jkvl... that helps clear it up.
    I want to tune my 03 6.0 HD for better mileage and it seemed like autove was my first step, but since the truck is completely stock it sounds like it will not do any good.
    Unknown Zone TAQuickness's Avatar
    Jan 2005
    You can always revert back to your stock tune for side by side comparison later.
  1. newbie question
    By Baldric in forum Gen III V8 Specific
    Last Post: May 12th, 2009, 05:43 AM
  2. Newbie with question.
    By WisconsinHick1 in forum Gen III V8 Specific
    Last Post: March 16th, 2009, 11:49 AM
  3. Newbie question...
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: April 22nd, 2008, 01:16 PM
  4. Another Newbie Question...
    By boating4five in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 17th, 2008, 08:47 PM
  5. Newbie Question
    By V7TTE in forum FlashScan V2 BB Logging
    Last Post: February 28th, 2008, 07:53 AM
