Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: 97 2bar
  1. #11
    Feb 2006
    % actually works.So far I'm ussing KPA vs RPM on auto VE which is getting it closer.Car is alot more drivable so far. Only thing I don't like is that the VE table is going into the 200's/300's on the tuning scale but it seams to be working.
  2. #12
    Aug 2005
    Quote Originally Posted by slowhawk
    That's what I meant. % units do not increase linearly. You can't just shift the 100kPa column into the 50kPa column initially and expect it to work (like you would expect), you have to increase it by another 40-60% for it to be safe...
  3. #13
    Feb 2006
    Quote Originally Posted by dc_justin
    Found that out Car still needs alot of tuning but I'm happy with it so far.
  4. #14
    Feb 2006
    Update- The car is pretty much done. We maxed out the 60lb injectors then added some pure Methenol. It runs real good but still has minimul holes in the tune.Car is Nasty, 1/4 throttle kills the tires in 1st/2nd then 3rd spins at 1/2 throttle.
    hopefully in the future there will be some kind of Custom OS for 97/98's but this will do for now.
  5. #15
    Junior Member Turbo595t's Avatar
    Sep 2005
    SlowHawk, where are you experiencing holes in the tune?
    I would rather be Blown, then bottle fed
  6. #16
    Feb 2006
    Quote Originally Posted by Turbo595t
    Ended up being the change between fuel cells.They have to be extremely smooth since they are limited without a custom os setup.The car runs real good now but not as good as some custom os cars I've done.The A/F isn't as locked as I would like.
  1. To 2bar or not
    By Slowrc in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 12th, 2010, 04:24 AM
  2. e38 2bar sd
    By b18cls1 in forum E37, E38 & E67 PFI ECM's
    Last Post: November 28th, 2008, 06:17 PM
  3. 2bar with mac e67?
    By SScarTuning in forum E37, E38 & E67 PFI ECM's
    Last Post: October 27th, 2007, 08:12 AM
  4. Scanning with 2Bar OS
    By TripleA in forum General
    Last Post: July 16th, 2006, 05:23 PM
  5. 2Bar ?'s
    By MN C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2005, 01:15 PM
