Results 1 to 4 of 4
Thread: available parameters on the LB7?
    Sep 2006
    Default available parameters on the LB7?
    I just got the Flashscan software, and after connecting to a 2002 LB7 and entering the VIN I was only able to view a subset of available parameters.
    For example, on the engine side I could not get MAF sensor amoung others, but more importantly to me could not get any of the Allison transmission parameters such as trans temp, slip, TCC %, torque etc. When the list of PID's came up, these were all labelled as unavailable.
    On my Snap On Solus scanner I can get all of this stuff. Any ideas? TIA.
    Todd
    Dec 2005
    Quote Originally Posted by forcefedjunkie
    Todd
    for allison parameters try this.
    Edit >> Properties >> Connection
    Change the controller I.D to $18 TCM
    EFILive Distributor Trippin's Avatar
    May 2004
    Quote Originally Posted by never satisfied
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Sep 2006
    Ok, so I followed the suggestions and was able to read some of the trans parameters - for a short time. Before I continue, is trans temp a transmission parameter found using the $18 TCM controller? It's called a "temperature" parameter on the display as opposed to "transmission". I could not read this at all no matter what I set the controller to.
    Anyway, the software decided it would set itself to "General" scan mode, and no matter what I did it would not go back to Dynamic or streaming, including trying Edit>Properties>logging. It would show "streaming" as the selection, but once back in the data table, General scan mode would be listed. In General Scan Mode, I continually get a error saying that another mode is required to view parameters. Closing and opening EFILive Scan would ocassionally default to streaming, but eventually locked onto general. I cannot link to the vehicle at all now.
    I'm running Windows XP SP2 if that matters.
    Todd
  1. New A6 Parameters
    By gmh308 in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: March 15th, 2009, 08:33 PM
  2. Any one know what parameters....
    By 98SS2836 in forum Gen III V8 Specific
    Last Post: January 16th, 2007, 05:01 AM
  3. What happened to the LL8 parameters?
    By blandmiller in forum General (Petrol, Gas, Ethanol)
    Last Post: August 15th, 2006, 05:55 AM
  4. outside parameters
    By wkdivr in forum General (Petrol, Gas, Ethanol)
    Last Post: March 6th, 2005, 02:13 PM
