Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: RR and 98' PCMs..
    Default RR and 98' PCMs..
    I know that the 98' is a rebel year for the PCM but seemed to believe I came across some post regarding the RR's compatibility with this wiring harness.
    We just bought a 98' Formula to be converted to a shop race car and really wanted to use a factory style PCM for engine management vs. a aftermarket system. Figure it would also be a good time to play with a RR PCM.
    What are my options?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Lifetime Member Doc's Avatar
    Oct 2005
    Red face
    I would go ahead with the pin swap Howard. Do you want to keep the instrument cluster (IC) functionality? If so start searching for an (IC). If you desire the fuel gage to function then go ahead and start looking for a 99+up plastic tank-might as well go ahead and incorporate a Racetronix or other brand fuel system upgrade for the 99+up while you are at it. I built up a cable to speed up 98 tuning with the RR but it is not a real full time fix-I have only used it on the dyno so far. I thought at one point there was talk of possibly having a 98 RR. Maybe Geoff or Craig could chime in.
    www.efialchemy.com
    www.greatamericancarwar.com
    May 2006
    I wish RR and custom operating systems would come out for 98's. I know it would make my tuning life easyer. Probably some shops too.
    Quote Originally Posted by Doc
    We are shooting for a mid 9 sec car with full interior and stock functionality so keeping the cluster is a key item. What is involved with the pin swap and are there any instructions/tutorials floating around? Getting a cluster is not a problem nor is the tank etc.... The fuel system is going to be from start to finish as the power level for our goal will demand it.
    Is the pin swap just about just switching over to a 99' PCM setup which requires the 99' dash and tank?? If so it doesn't sound like a big deal. I love electrical wiring!
    Is the 98 vs 99 PCM very different? Obviously engine management wise there should be no difference. I can see the dash and tank stuff being the bigger issue.
    Now I need a picture of both PCM pin outs!
    Howard
    1-954-703-5560
    Jan 2005
    RMS - I'll see if I can dig it up, but somewhere in here Ross posted pic's of PCM guts. 98's are substantialy different.
    Jan 2004
    Let me talk to Craig HT. We might be able to get you into a 98 RR if you will ship him the PCM.
    Feb 2006
    Howard I have done the 98 to 2002 PCM swap a couple of times. The later OS is better and has custom systems available. You can keep the stock 1998 cluster working with the 02 PCM. I have detailed schematics and pin swapping information, just haven't created the web page yet! The evap system will not function correctly, don't think this will upset your combination. Contact me if you need some of this info.
    AL
    Oct 2005
    Al, did you get the fuel gage to work on the 98 after the swap? I thought what with F0501 and F0507 being different btw the years plus the different sending units, evap system, etc. that the Instrument cluster's fuel gage would not work? I went ahead and got a plastic tank, IC, and racetronix 99+up fuel system upgrade and it all works. I don't doubt the work you have done Al, I just would like to learn.
    www.efialchemy.com
    Oct 2003
    I'd love to see this as well, I have three 98's I would convert nearly immediately.
    Quote Originally Posted by Black02SS
    Chad,
    Thats all I want to do! Its for the shop car and it makes no sense not to use a RR unit.
    The PCM is sitting on the front seat so let me know!
    Before I go looking, will it still require a IC change?
    HT
    1-954-703-5560
  1. list of 411 pcms anyone?
    Last Post: April 19th, 2010, 10:49 AM
  2. LS1 PCMs
    By Harrismarine in forum General (Petrol, Gas, Ethanol)
    Last Post: June 11th, 2008, 12:07 PM
  3. Vortec PCMS
    By chevy052500hd in forum Custom Operating Systems
    Last Post: March 11th, 2008, 01:52 PM
  4. lbz pcms for sale.
    By wait4me in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 16th, 2007, 03:14 PM
