Results 1 to 4 of 4
Thread: Boost Sseems Low?
    Dec 2005
    Unhappy Boost Seems Low?
    On my Brother's 01 LB7 we were logging some data and he was only showing about 16lbs of boost. It was around 16lbs and idle too, but his edge was showing totally different numbers. It there something we need to do to show the right boost numbers with EFILive 7.3?
    2002 6 SPEED SILVERADO?!
    Oh yea, that new auto transmission GM came out with? NO, 6 SPEED MANUAL! You know 3 PEDALS!
    309RWHP 341RWTQ - 14.096ET @ 96.69MPH
    Dec 2005
    Anyone?
    Which PID where you looking at?
    Also, keep in mind, the in-line boxes mess with sensor readings!.
    Dec 2005
    CALC.ACTBOOST
    Oh yea, Never thought of that. I guess he should just get a gauge pillar then.
  1. Boost VE map...............
    By FreddyG in forum Custom Operating Systems
    Last Post: October 19th, 2007, 10:21 AM
  2. What AFR in Boost?
    By zapp168 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: July 24th, 2007, 01:03 AM
  3. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  4. Boost and EGT's
    By minytrker in forum Duramax LB7
    Last Post: February 14th, 2007, 03:41 AM
  5. What happens when you go into boost?
    Last Post: March 29th, 2005, 05:49 PM
