Results 1 to 10 of 10
Thread: EFILive File locations
    Lifetime Member Cougar281's Avatar
    Jan 2006
    Default EFILive File locations
    Is there any way to move the files that EFILive puts in the "My Documents" folder? My "My Documents" folder is stored on my server, and I have offline files enabled. Normally, this is not an issue, but my MS Money file got FUBAR'd due to a network disconnection while it was in use. Don't want that happening with EFI.
    Oct 2004
    Can can relocate the folders and change the locations in the Scan Tool properties. I found originally (over a year and a half ago) that when you performed installation upgrades that files would still appear in the "My Documents" folder. I gave up in the end and have had no issue since...
    Could you use EFILive as a different user logon perhaps that didn't have network folders?
    Andrew
    EFILive Crew
    EFILive Distributor Trippin's Avatar
    May 2004
    Launch the Scan tool and go to Edit>Properties>Folders tab.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Oct 2005
    I think its a good idea in v8 of the software to have a common file root. Splitting them up is a little confusing and messy IMO.
    2014 VF SV LS3 Maloo.
    Quote Originally Posted by ringram
    I agree 100%.
    Stupid Microsoft "guidelines" that recommend putting program files in "Progam Files" and data files into "My Documents".
    Everything will be in one place in V8.
    A full uninstall will be as simple as deleting the folder.
    Also the registry will not be used. All config data will be stored in text files that can easily be changed, deleted or replaced.
    Jan 2005
    I used to have the same problem as I keep my program files on my C partition and data on the D partition. I didn't have the luck I was looking for by adjusting the properties. However, I did find the registry key's that store this information. After manually updating the registry, I exported the key's for quick re-entry.
    Jul 2004
    And don't forget how much harder you make it for the average user to back up if you don't follow those rules. Is it really that hard to delete 2 folders instead of 1? I can understand not using the registry, but forcing data into Program Files is really not a nice thing to do. If you want, offer it as an option during the installation, but please don't make it the only option.
    Ira
    Smile Myopinion
    I agree 100%.
    Would be a good idea to make a program root and a data root, and they can be the same or different, the user selects at install time and can change at any time via folder properties.
    Not using the registry is a very good thing.
    Lifetime Member Garry's Avatar
    Jun 2006
    Spoken like a good programmer, not one of those Windoze "Programmers" Thank you!!! Nice to see that no everybody follows M$' errors blindly ...
    Garry Glendown * '17 Fifty 2SS MT * 99 Firehawk Convertible (for sale)
    Jun 2006
    Why does everybody sane seems to know this, but not M$ horde of well-paid developers?
  1. I somebody emails me a HPTUNERS file, can I load it into a car with my EFILIVE??
    Last Post: March 24th, 2010, 12:01 PM
  2. Need help. Trying to read ls1edit file with efilive
    By BrianC98Z28 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2007, 02:23 AM
  3. EfiLive file format question...............
    By FreddyG in forum Gen III V8 Specific
    Last Post: January 4th, 2007, 11:29 AM
  4. Convert LS1Edit File to EFILive ... Help!
    By superls1 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2006, 03:00 PM
  5. If I open an HP file from Horists site W/EFILIVE, can I load it right into my pcm??
    Last Post: December 28th, 2005, 09:43 AM
