Results 1 to 4 of 4
Thread: Known issue with ECM/TCM combo
    Default Known issue with ECM/TCM combo
    Known issue with the current version of the EFILive software.
    When EFILive validates the PIDs it stores the validated PID list in a file called
    \My Documents\EFILive\V7\PIDs\<VIN>.vpl
    where <VIN> is the first 11 characters of the VIN, and for US VINs the 9th digit (the
    checkdigit) is replaced with an underscore.
    Some sample *.vpl files:
    1G1YY34U_55.vpl (American style with the checkdigit removed)
    6H8VTL69FYL.vpl (Australian style with no checkdigit removal)
    Anyway, the ECM (Engine controller) and the Allison TCM (transmission controller) both use the
    same VIN. What happens is on the first connection to the ECM, the ECM PIDs are validated and
    stored in the appropriate <VIN>.vpl file. Then when a connection to the TCM is made, a matching
    <VIN>.vpl file is found (the ECM pid list) and EFILive assumes the PIDs listed in that file are
    valid for the TCM. Obviously they are not because they are ECM PIDs.
    The workaround:
    1. Locate the *.vpl file that matches the vehicle's VIN in the folder:
    2. Delete it.
    3. In the EFILive Scan Tool software, open the properties window (menu: Edit->Properties)
    4. Select the [Connection] tab page.
    5. Select the Controller ID: of "$18 TCM".
    6. Connect to the TCM (menu: File->Connect).
    7. Re validate the TCM PIDs (menu: Info->Validate PIDs).
    When changing back to the ECM, you need to repeat the process (including deleting the *.vpl
    file) but change the controller ID back to "$11 ECM".
    The Fix:
    This problem has been fixed in the next release of EFILive. The next release will be available
    in October.
    Paul Blackmore
    EFILive Limited
    Lifetime Member Whippled 496's Avatar
    Sep 2006
    So is there any way to scan using the PIDs from the TCM and the PCM at the same time? If i wanted to scan say "GM.TRQENG_B" and "GM.kr" at the same time is that possible right now? If not, will it be possible once the new update comes out? Im trying out different scanning templates and would like to be able to scan engine knock in relation to requested torque reduction from the Allison. Here is a couple screen shots of one of my PID templates. I am not able to scan all these at the same time.
ID:	997   Click image for larger version.
    2014 GMC 2500HD RCLB SLE
    LML / Allison
    Scanning both at the same time will not be available until Version 8 is released - mid to late next year. Even so, the scan rate will be slower because the Class-2 bus bandwidth will be shared between the ECM and the TCM.
    Unfortunately that's just the limitations of the in-vehicle network.
    Sep 2006
    Why dont you hook me up with the version 8 beta release?
    Thanks for the info Paul, while i have you on the line I have another question i was hoping you could answer that is within the same topic of this thread. There seems to be some oddities with the 8.1L/Allison setup in regards to the software appearance. With the 4.8/5.3/6.0 coupled with the 4L60E-4L80E the transmission tuning is done directly in the PCM screen. With the Dmax, there are no transmission options in the PCM screen at all. BUT...in the 8.1L/Allison PCM screen there ARE transmission as well as torque management and traction control options. I would have assumed the transmission calibrations and diagnostics would be greyed out in the 8.1L/Allison PCM screen (or not there at all like with the Dmax) because they ~shouldn't?~ have anything to do with making transmission changes. Everything in those transmission screens is referencing 4 speeds, not 5 like the Allison. Basically what i am asking is since those options (transmission options) are still visible to me even though i have an Allison and a seperate TCM.....what if anything inside those areas will be usable? how about traction control and torque management? Anything in those areas that are usable? Can i alter torque management, max torque limits and other things in those tables if i have the Allison and TCM?
    Thanks,
    Jimmie
    LML / Allison
  1. strange acting T42 4L60E combo with 4wd tun file
    By harascho in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 11th, 2011, 02:51 AM
  2. Replies: 21
    Last Post: January 9th, 2010, 12:27 PM
  3. LS2 / L92 Combo with cam Tune
    By Gelf VXR in forum Gen IV V8 Specific
    Last Post: September 16th, 2009, 09:10 AM
  4. Finding a tune file for a similar combo?
    By thunderstruck507 in forum Gen III V8 Specific
    Last Post: June 27th, 2009, 09:31 AM
  5. DTC issue?
    By Cougar281 in forum Duramax LLY
    Last Post: June 2nd, 2008, 09:32 AM
