Results 1 to 10 of 16
Thread: TCC Lockup During Shifts?
    Oct 2005
    Default TCC Lockup During Shifts?
    Comparing my truck tune to a Z06 tune I noticed that TCC Lockup during upshifts(D2801) is disabled in the truck tune but allowed in the Z06 tune(the TCC lockup speeds are sometimes less than the shift speeds in the Z06 tune).
    I have altered my shift tables to yield downshifting that is more suited to engine load similar to the Z06 tune. But now I have TCC lockup speeds that are only slightly higher than the 2-3/3-4 upshift speeds. So I get a double kick in the seat with the upshift closed followed by TCC lockup. Not to mention the kick as the TCC applies and releases if traffic happens to be moving close to the TCC Apply speeds.
    Would there be a problem with setting up a truck to have TCC Apply concurrent with an upshift? What about when towing? I have a built trans and PI multi-disk TC.
    Should the TCC Pressure tables be modified for this TC?
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    It's ok for the TCC apply speeds to be lower than the upshift speeds... the TCC apply should occur immediately/concurrently on upshift;
    the reason trucks/towing have TCC apply speed above the upshift speed is that they are heavier and can benefit from the torque multiplication (which occurs while TCC is not applied and TC is slipping due to engine torque being applied).
    I don't know about pressure.
    Lifetime Member jfpilla's Avatar
    The stock C5 A4 table has NO selected. The Z06 has YES. Since the Z06 doesn't have a converter I guess it doesn't matter. Was a Z06 file used and not just some tables copied?
    Oct 2005
    Thankyou
    Quote Originally Posted by jfpilla
    Yes, I guess it would be hard to hurt the converter then. This was the Z06 tune that came packaged with the EFILive download. I haven't downloaded an C5 A4 tune to look at yet. I assumed that the tables in the Z06 tune applied to the A4.
    I tried setting the TCC apply a little before the upshift VSS but it still seems to apply after the shift. Haven't tried changing D2801 to YES yet.
    Also noticed that, while cruising in 3rd just over my Lockup VSS of 60 KMH, whenever the TP falls below 20% the TCC goes to OFF. Even though I have all TCC Release speeds for 3rd set at 50 KMH up to 31.25% TP. VSS was constant at around 65 KMH. So the TCC is constantly locking/unlocking while cruising at this speed.
    One more question. I have lockup disabled for 2nd(all VSS set to 412 KMH) but i see that TCC enable is constantly switching on and off in 2nd. Is this normal?
    Are you looking at the pid GM.TCCMODE to see if the TCC is being commanded locked...?
    Oct 2005
    Yes. In this screenshot the TCC is locking/unlocking.
    A little further along in the log it stays locked even though there are blips where TPS falls below 20%.
    Then later TP falls below 20% but TCC goes to Coast mode rather than releasing. What determines whether Coast mode or TCC Release is commanded?
    Have you tried setting the misfire tables to 32000?
    Oct 2005
    No. Should I log some misfire PIDs to determine if the TCC release is related to a misfire situation(real or false).
    I would just set C5621 to C5627 to 32000. If it corrects the unlocking you can go back and track the missfire.
    Oct 2005
    OK, tried that. The TCC is still behaving the same. Did notice that it remained OFF until the TFT reached 75*C or so. Not sure if this is normal.
  1. TCC lockup again
    By DURAtotheMAX in forum Allison 5 & 6 Speed
    Last Post: April 23rd, 2011, 02:21 AM
  2. TCC lockup quicker w/80E
    By nonnieselman in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 11th, 2008, 07:06 AM
  3. Soft lockup
    By jfpilla in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 10th, 2007, 12:16 PM
  4. TCC Lockup While Coasting
    By RonC in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 28th, 2007, 05:33 AM
  5. TCC Lockup Issue
    By DrX in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: December 28th, 2006, 06:22 PM
