Greetings EFILive users, some good news for you all, we are now offering as a pre-release new calibration files to enhance your tuning experience.
In this zip file is new calibration files for LB7 & LLY's, these files define all the maps you see in EFILive.
We have added in a lot more tables thanks to the feedback from everyone out there, from tuners running 11's to those wanting better MPG.
The LLY now has over 270 tables / parameters to tune giving everyone using EFILive unequaled tuning control over your engine.
Whilst the LB7 tuners might feel they have missed out with nearly 200 tables / parameters they have not, it is simply a case of the GM programmers adding in more tuning control into the LLY programs.
So a quick list of what is new -
More Fuel Pressure control tables
More Main and Pilot control tables
DIC accuracy adjustment table
4WDLo Fuel Delivery Dampening table (LLY only, pullers will like this)
Some PTO control
Also in the zip is the most recent DSP² tutorial and a DSP² O.S for the 2001 trucks.
As these are still considered as pre-release files it is suggested you back up any files that will be replaced from this zip, or, have your install CD handy if you need to revert back.
Unzip all the .cal files into -
\Program Files\EFILive\V7\Calibrations
Unzip the LB7_DSP2_01887301.tun file into the directory where you store all your other DSP² base files.
Unzip the DSP² Upgrade Tutorial.pdf into -
\Program Files\EFILive\V7\Doc\Tutorials
There will be another update coming shortly which will add more scantool functionality for tuning the Duramax.
Happy tuning...and please let us know if you run in to any troubles.
DOWNLOAD ZIP FILE HERE (3.3Mb)
