I was considering just shooting off an Email, but in the hopes that this may help others, i decided to just make it a thread first. I am having some very strange and difficult to resolve issues with knock. I have a whipple supercharged 2003 8.1L/Allison and there does not seem to be a whole lot in the way of information on these suckers and its making tuning very very difficult. I have tried tunes with single digit timing numbers, I have tried 110 octane CAM2 fuel, I have my AFR and VE tables dialed in tight. I am still getting consistant knock as high as 7* sometimes through out my RPM range. I have my burst knock table zero'ed out and for the most part the tune is pretty conservative. I have nothing in the engine bay clanging or banging that would induce any false knock, and the engine runs strong otherwise. Thats the story. One thing I found is that on all LS1 stock and modified tunes that i looked at, table B6227 (knock sensor filter) had the sensor filter set at 4.70. Mine was set at 7.90, not sure why or what effect that has. Would the 7.90 setting make my sensor more or less sensitive? it that a setting that should even be adjusted at all? And what effect would making adjustements in that table have? I set mine back to 4.70 and it seemed to clear up a little of the knock, but not a whole lot. I would very much like to see a tune of a modified 8.1L truck if anyone has one or has any intimate knowledge of tuning them. Here are 2 logs and the tune i used for those logs. One log is with CAM2 and the other is not. If anyone can see anything here that stands out to them please let me know....Thanks
Jimmie
