I was trying to hook my LC1 up to do some logging.
I got to the 02-wide pull down but there are no pids there. I have v7.3.2 am I doing something wrong? If I unselect "supported" i can select them but it doesn't work
Welcome to the forum 1BADAIR.
From the sounds of it, the WB pid has the red X thru it. Right click the PID and select more info. You will get a pop up describing the other pid's you need to select so you can log your WB.
I think I got it.
thanks
I am pretty sure I have posted here before but for some reason my count still says too
