Results 1 to 5 of 5
Thread: Weird bug
    Jun 2005
    Default Weird bug
    I've been trying to figure out what's going on here. It has to be some kind of glitch. I open my friend's tune (A4 w/ stock tires and 4.10s) and go to the speedometer section. Then, I notice the calculated tire height is 25.49 and not the normal 24.91. I assume this is because the maximum setting for H0101 is 129759 pulses/mile. I say to myself, "OK, 1/2 inch isn't that big of a deal." But then I noticed when using the compare feature (tuned vs. stock), if I go to the same H0101 from the compare window the maximum has changed to 128462. Now his calculated tire height is 25.75. What's going on here? Also, are people who get 4.56 gears pretty much screwed when it comes to the speedometer? Just curious...
ID:	988   Click image for larger version.
    Sep 2003
    My speedo works fine with the 4.56's i just left the tire size wrong the way GM coded it
    Larry - HumpinSS
    Jun 2005
    PCM limitations I can understand. What's really throwing me is why the maximum pulses per mile is inconsistent.
    Can you send me both files so I can investigate, please? (paul@efilive.com).
    Jun 2005
    You've got mail...
  1. Weird fan problem
    By johnsZ06 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 25th, 2008, 02:20 PM
  2. Weird VIN
    By rgullett83 in forum Duramax LB7
    Last Post: September 3rd, 2008, 02:47 PM
  3. Weird AFR at idle
    By 5.7ute in forum Custom Operating Systems
    Last Post: December 7th, 2006, 12:04 PM
