Results 1 to 8 of 8
Thread: LC-1 work with flashscan
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Default LC-1 work with flashscan
    Going to order the LC-1 from the makers of LM-1. Will the LC-1 work with flashscan?
    Sep 2003
    As long as you have an analogue output Flashscan will work with it
    As Dirk said, you just need an analog voltage output.
    On this web page:
    http://www.motorsportsinnovations.com/wide_band_o2.htm
    The LM-1 is shown with the following feature:
    "0-5 volt output for any Data Acquisition system"
    If the LC-1 has that same feature then it will work with FlashScan.
    Apr 2004
    Like the LM-1, the LC-1 has 2 analog outputs that you can freely program. Look at the LM-1 manual for details. The analog out programming of the LC-1 is identical. The only difference is that the LC-1 has separate grounds for heater and system. This way the ground offset issues of the LM-1 analog outs are minimized or eliminated. Also the output resolution of the LC-1 is 12 bits (~1.2mV) while the LM-1's analog outs are 10 bit (~5 mV).
    The analog outs are completely independent of the serial stream that feeds the XD-1 or (future) LogWorks.
    Regards,
    Klaus
    Found this on there website
    Nov 2003
    I just ordered a LC-1. VE table here I come...
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Lifetime Member mistermike's Avatar
    Dec 2003
    Do you have to know someone to buy these. I signed up for their newsletter and check the site regularly, but there's no word on availability.
    World's First Twin Screw Pontiac GTO
    2004 GTO. Blown H/C 408, stage 3 keyboard, billet tires
    2017 Chevy SS with dead hooker is spacious trunk
    2014 Chevy Cruze. MPG queen with my balls in spacious glove compartment.
    www.aussiemotive.com
    Nov 2003
    Quote Originally Posted by mistermike
    Call Chris At:
    APEngineering
    586-954-3181
    Bill
    Dec 2003
    Quote Originally Posted by BowlingSS
    Call Chris At:
    APEngineering
    586-954-3181
    Bill
    Thanks, Bill!
  1. will flashscan v2 work on 3.4l grand-am
    By Eric in forum Gen III V8 Specific
    Last Post: August 31st, 2009, 03:14 PM
  2. scanner buttons work work?
    By pullincrazy88 in forum FlashScan V2
    Last Post: May 16th, 2009, 01:12 PM
  3. Will EFILive/Flashscan work on my '97 C5?
    By ViciousVette in forum General (Petrol, Gas, Ethanol)
    Last Post: January 26th, 2005, 07:23 AM
  4. Would this WB02 sensor work w/ Flashscan?
    By AllCammedUp in forum General (Petrol, Gas, Ethanol)
    Last Post: October 1st, 2004, 10:57 AM
  5. Links to widebands that will work with Flashscan/EFIL please
    By DebianDog in forum General (Petrol, Gas, Ethanol)
    Last Post: February 17th, 2004, 04:22 PM
