I have a 2000 SS, changed out intake to LS6 and injectors to 28.8, other than changing the injector flow rate chart, is there any other changes that need to be made to the 2000 OS? I have changed the injector flow rate out for one from a stock 2002 file
Car seems a bit lazy and throttle response seems to be poor compared to stock intake and injectors.
Thanks for any help or suggestions, I'm new to this tuning deal. I want to be sure that any fixed parameters are correct before changing any fuel tables based on current fuel trims.
