Results 1 to 10 of 19
Thread: Road Runner DEAD????
    Jul 2003
    Default Road Runner DEAD????
    PCM doesn't want to communicate with the vehicle... Its installed in a z06 2001.
    The PCM is giving me P1516 TAC output or something... And Engine Overheating, reduced engine power bla bla bla modes.
    The ECT is reading 260F ALL The time...
    The PCM worked great for a little while.. after that.. the car shut itself down.. later.. it "unlocked" and then you could start the car.. now its giving problems again...
    Anyone with first hand knowledge of this???
    The PCM doesn't want to display trouble codes via the IPC. When it works fine it does.
    Ideas?
    Junior Member carneb's Avatar
    Do you have your laptop connected to the RR when these problems happen? They can act strange especially if the laptop is being powered in the car by an inverter.
    Out of interest did you mess with the ETC tables?
    Jul 2003
    No i didn't... I am very smart not to mess with the ETC tables... no need...
    One thing though... the laptop is powered by its battery...
    I am considering asking craig about it.. but want to know your first hand experience.
    THx
    Remove power from the RR , repower up after a few mins and use a mains power supply to the laptop , reflash the full tune back in and see if it fixes the problem.
    I have come across a issue where the power to the USB seems to drop too low and corrupts the flash on the RR
    Feel free to get with me and we can get you taken care of if needed.
    Sounds like you might be on the right track to get things figured out, but let me know if you need any help.
    Jul 2003
    Did this.. wont fix...
    as a matter of fact.. if you put it in flash mode... it will not start BUT it will not read 260F ECT.
    As soon as you put it in Emulation mode... it goes right to 260.
    Tried to flash the flash portion using normal efilive... Bootloader rejected... THIS IS ALL IN CAR...
    The PCM was removed.. will check it tommorrow and see if outside the vehicle it works... but.. won't in vehicle.. Changed to the normal PCM, car fired right up.
    Jul 2003
    Ok... PCM out of vehicle will not program flash portion, saying rejected bootloader 1) mph above 0 2) rpm above 0 OR 3) Bad RAM!! :( ... USB portion programs OK, reads ok, just like it did when in car...
    Is there any way to test this pcm other than installing it?
    Oct 2005
    Sounds like a call to the doc. Possible rush to hospital required.
    2014 VF SV LS3 Maloo.
    When emulation is disabled (flash enabled), the RR will do nothing. None of the new units have flash installed, so turning the flash on is basically the same as turning the emulation off.
    Sometimes you can get the unit to 'reset' if you turn the emulation on and off while the PCM is powered up in vehicle or on the bench via bench harness.
    So in answer to your question, just make sure that it is set to emulation and don't be in any way concerned/interested in how the RR PCM responds to any flash-based read/program commands. It won't respond.
  1. Road Runner is frustrating me
    By billyjo in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 2nd, 2007, 04:46 AM
  2. Need help with Road Runner ASAP
    By esco35m in forum RoadRunner Real-Time PCM Emulator
    Last Post: July 31st, 2007, 05:41 PM
  3. Can't connect to Road Runner
    By BlownAlaskan in forum RoadRunner Real-Time PCM Emulator
    Last Post: June 7th, 2007, 03:46 AM
  4. 1998 Road Runner?
    By 1998ws6 in forum General (Petrol, Gas, Ethanol)
    Last Post: August 21st, 2006, 03:08 PM
