Results 1 to 8 of 8
Thread: A-4 in third for Dyno
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default A-4 in third for Dyno
    When I was dabbling with the Predator, James at RWTD said he could create a tune to keep the transmission in third gear (1:1) for dyno runs.
    Can I do the same by just using the bidirectional controls on the dyno?
    Get the drum rolling, let it get to third, then lock it in third with the Bi-Dir; do the pull, then unlock it?
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Should be able to; can also lock/unlock the TCC if required.
    Dec 2004
    with a bit of wiring and an extra switch you can have full manual.been meaning to try it ....d0409.......these options enable the various shift pattern modes within the PCM.
    Note: J1 is the 'BLUE' connector on the PCM.
    Switch types used must be momentary connect to ground.
    'No Switch' = Performance mode via a switch is not functional.
    'One Switch' = Performance mode via a switch can be activated (J1 - pin71).
    'Two Switches' = Performance mode via a switch can be activated (J1 - pin71), and Manual Mode can be activated (J1 - pin31).
    'C2 Data Bus' = Shift pattern modes are sent on the data bus to the PCM from another module, eg - BCM.
    Only the following values may be entered into this table:
    - No Switch
    - One Switch
    - Two Switches
    - C2 Data Bus
    Jan 2006
    Quote Originally Posted by zrx1200
    - No Switch
    - One Switch
    - Two Switches
    - C2 Data Bus
    So if I used one switch, I could switch between normal and performance mode and run 2 differnt shift modes on my camaro?
    Lifetime Member Doc's Avatar
    Oct 2005
    Yes I do believe you are on the right track. I think it would be like the "Tow/Haul" mode on a Silverado.
    www.efialchemy.com
    www.greatamericancarwar.com
    Jan 2006
    Cool, thats what Im looking for. I want to do a street n/a setup and strip n2o setup. I will have to try it out in the next few weeks when I get the car finished hopefully.
    Member Treurentner's Avatar
    Nov 2005
    Hi,
    thats very interesting info for the later OS. But how to activate the performance mode tables on the 97/98 PCM under OS #9352031 (97th vette).
    The tables are already there but how to switch them on?
    In the cal is no D0409...
    Marco
    Quote Originally Posted by Beer99C5
    I do that all the time when pulling a A4 on the dyno. I get the car into 3rd gear, select 3rd gear and also lock up the converter. make the pull and deactivate the TC and deselect the gear.
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
  1. New Dyno Results
    By vatman02 in forum Gen III V8 Specific
    Last Post: March 19th, 2008, 06:47 AM
  2. 08 Z06 and AFR on the dyno.
    By 02Z06 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2008, 10:04 AM
  3. went to the dyno look at my log
    By warscout2 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 18th, 2007, 04:22 PM
  4. Dyno success on Dynolog Dyno
    By oztracktuning in forum General (Petrol, Gas, Ethanol)
    Last Post: April 2nd, 2006, 12:31 AM
  5. My C5 on Dyno!
    By nco663 in forum Lounge
    Last Post: January 27th, 2006, 06:11 AM
