Well after bunches of help from DCJustin and 02Sierra as well as a few others, i am on the right track now with my tune. Seems my knock sensor filter was not set correctly (7.90) and needed a little time to adjust to the proper setting (4.70). Now everything in the KR separtment is looking good. Getting ready to do a MAF dial in and get my spark and IAT tables pegged down. The VE is very close with a BEN factor on average of about 0.8-1.1. And the Spark table is real close, i just want to tweak it out. My LTFT's are off some, but i will work on that too.
The other issuse i have (not a real big deal) is when i start the truck up for the first time, i find it needs to crank a little more than it used to and its hesitant to fire right up. After its warm, it fires up with no problem at all. It seems to idle fine (warm or cold) its just that first cold start. The truck is not a daily driver, i use it on the weekends and for vacation mostly. It gets driven maybe 50 miles a week and usually just on Fri, Sat, and Sun. What do i need to adjust to get this thing to fire up on cold starts like it used to?
