Results 1 to 4 of 4
Thread: MAF Tuning and Dry Nitrous
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    Default MAF Tuning and Dry Nitrous
    Assuming that VE and the MAF tuning pans out, will there be cells in the upper MAF freq area (B5001) I do not hit NA? Keep in mind if I was home I would try it instead of asking it
    That being the case I believe I will hit the higher cells when spraying the dry shot through it.
    If that is true, I should be able to manipilate the upper MAF freq "Value" in table B5001 seen only with Nitrous to trick the PCM to targeting say 11.5-12 AFR when spraying dry only? Or does PE have priority over what the MAF says?
    Probably done/tried already by someone, but I have not read anything about trying this idea, or if its feasible or not.
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
    Jan 2005
    PE works in conjunction with the MAF and/or VE. The MAF/VE table will tell the PCM how much air mass is flowing in. PE describes the desired mixture. This ultimately calculates to an injector pulse width.
    Jul 2006
    So what I described may work and is worth my time looking into and playing with? It will default to the richer of the two (MAF table vs VE table?)
    Maine USA
    Jan 2005
    no sir. above 4k (OEM setting) the PCM looks at the MAF only (assuming you're not in SD). "Selecting the richer of the two" you speak of occurs with the fueling tables, PE or the open loop fuel table.
    Although I would not recommend it, you could trick the PCM into adding more fuel by raising the repective values in the MAF/VE tables. More air = more fuel.
    You might check with Black02SS or Patrick G (from LS1Tech) for more details on setting up the tune for a dry shot.
  1. nitrous help
    By blue99ta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: August 26th, 2009, 05:40 AM
  2. Nitrous COS for 2006 E40?
    By KAZ MotorSports in forum Gen IV V8 Specific
    Last Post: May 23rd, 2008, 03:51 PM
  3. Tuning LLY w/ Nitrous
    By 02gmcwaldoch in forum General (Diesel)
    Last Post: October 10th, 2006, 12:45 PM
  4. Nitrous Survey
    By GMPX in forum Custom Operating Systems
    Last Post: May 15th, 2006, 08:49 PM
  5. Nitrous controller via the pcm?
    By wait4me in forum General (Petrol, Gas, Ethanol)
    Last Post: June 6th, 2005, 03:15 PM
