Our county has done away with emission tests as of 1 Jan 07, and of course I need one in Nov to re-register my '02 Vette.
Here is the problem; I am running twin turbos, bigger injectors, Custom OS and AutoVE tune with MAF disabled according to tutorials posted in EFILive.
What will I have to do to pass emissions test? I think this test will just plug into the OBDII connector to test emissions.
Options:
1. Should I load a stock tune and OS, rescale the injectors, drive carefully to stay out of boost, go get emissions tested, pass, reload current tune and OS and be happy. Will this work?
2. Turn off the NO MILs that were turned off in the Custom OS Tutorial, be careful to stay out of boost, get emissions tested, pass, turn the NO MILs back on and be happy. Will this work?
3. Other suggestions?
Lonnie
