Results 1 to 10 of 16
Thread: Live Real Time Tuning?
    Apr 2005
    Default Live Real Time Tuning?
    does efi live tuner allow you to change parameters in real time, or just change and then reflash?
    ie.. can you change a VE cell at 3000RPM at 95kpa in live time on the dyno and have it change immediately where you would see the a/f change in real time? stuff like that.
    thanks
    Aug 2004
    That would be nice, but not a possibility.. I already asked..
    Apr 2005
    not possible because of the pcm, right? it can only be flashed not changed in real time.
    that is what i figured.
    Actually, EFILive V5 can do that for spark and fuel.
    I am going to add it back into V7 in one of the next releases.
    And yes I have been getting flak over not having it back in V7 sooner - I did not realise it was a useful tool when I decided to leave it out of the V6 upgrade :( sorry.
    You can still download and use V5 to do that if you want.
    If you need a V5 license send me your current V6 or V7 license and I'll send you back a V5 one. (paul@efilive.com)
    Download V5 from the bottom of the V6 download page.
    http://www.efilive.com/downloads/downloads_old.html
    It works well on a dyno for testing spark and fuel settings on the fly, with engine running, without reflashing. But it is (in my opinion) difficult to set up. I want to make the V7 one *much* easier to configure and use.
    Jun 2003
    YAHHHH!!!!
    And I thought I was the only one that kept v5 on for that reason
    Apr 2005
    totally sweet! any ETA on the v7 version?
    also, does it have the ability to show in real time what cell in the map you are in? ie..if i rev the car under no load control will the highlighted cell move around?
    thanks
    Quote Originally Posted by Nox
    thanks
    Yes, it follows the current cell in real time.
    You can do a similar thing in V7 (not real time though).
    If you run the Scan Tool and the Tuning Tool at the same time, as you move the mouse over the charts of a previously logged data file the Tuning Tool maps will show the current cell.
    If you select a range of data in the Scan tool charts, the Tuning Tool will highlight all cells used in that range of scanned data.
    The file:
    My Documents\EFILive\V7\User confguration\cal_link.txt
    contains all the PID to table mappings
    The next release is V7.1.9 which is due out (publicly) this month. It's due out in a pre-release configuration in a week or two.
    The 98 support is scheduled to follow that.
    The release after that will most likely be V7.2
    That release will contain the real-time maps.
    ETA on V7.2 is 1-2 months.
    Apr 2005
    thanks again paul. i appreciate the info. anxiously awaiting the real time maps.
    if i were to go back to version 5 for this, what would i be giving up?
    I forgot to mention this one important point, V5 does not support FlashScan - you need an AutoTap interface cable (AT1 V2 or ATU V3) to run V5.
    You can leave V7 installed and install V5 as well.
    If you make log files with V7, you can't read them with V5.
    If you make log files with V5, you can read them with V7.
    If you're asking what features are not in V5 that are in V7 - the list is long an includes (off the top of my head):
    - LS1/LS6 specific info
    - DMA PIDs
    - Customizable maps (pivot tables)
    - More indepth EPA test results
    - Tuning Tool integrated data
    - FlashScan support
  1. Real Time tuning w/o Road Runner?
    By Treed ya in forum General (Petrol, Gas, Ethanol)
    Last Post: May 20th, 2008, 06:40 PM
  2. HP Tuners Custom OS for Real Time Tuning compared to EFILive RTT?
    By N0DIH in forum Custom Operating Systems
    Last Post: July 14th, 2007, 03:23 PM
  3. Spark tuning in real time....
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 18th, 2007, 10:15 AM
  4. RoadRunner Real Time Tuning
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 08:47 AM
  5. Real time tune ?
    By Clubsport R8 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2004, 12:13 AM
