noob here - when linking data logs to my VE tables, the rpm cells are correct, however the kpa cells never move away from 30 kpa even though the logged data is clearly showing kpa'a in the 90-95 area?
to be more clear at 5500rpm the log shows 94kpa - the map shows that the pcm is at 5600rpm, but only 30 kpa?
any ideas?
