This one is in the process of getting a new transmission as the stock one finally gave up on this last pull. Slipped 3rd gear pretty bad as the graph shows.
Stock 5.3 except camshaft, Whipple on 9lbs, Custom TDS Intake, 42lb injectors, EFI Custom 2 Bar OS, 2500 stall 10" converter, 93 Octane and mild timing. This thing is NOT intercooled at all!
Future plans for 6.0 block build, water to air cooler, and 14lbs.
