Results 1 to 10 of 11
Thread: Bars
    Senior Member NewV's Avatar
    Nov 2006
    Default Bars
    Probably a very dumb question but one I feel I should understand before I melt something. What exactly is meant by 1 Bar, 2 Bar and 3 Bar?
    2005 CTS-V w/tuner wannabe driver
    Pretty sure it is the MAP pressure when going into boosted modes (2, 2.5, 3 Bar), I know 1Bar is regular tuning which is what most (if not all) cars/trucks come with. The 2Bar, 2.5Bar, and 3Bar OSs give more tables for tuning under boosted conditions allowing better performance when boosted.
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Places where you drink or if in FI situations. 14.7 PSI is 1 bar, 2 bar is double that and so forth. It refers to Pressure. I run 12.5 PSI on top of the 1 bar 14.7 PSI so I'm not quite 2 bar under full boost.
    I sure hope I got that one right! If not, I'm sure I'll hear about it.
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Nov 2006
    Quote Originally Posted by eboggs_jkvl
    Places where you drink ...
    Elmer
    I understand that first part.
    So if you are refering to MAP at double boost for 2BAR what controls that boost? Assuming richer AFR and more spark?
    1 bar = 1 atm = 101.3 kPa = 14.6 psi
    bar is a unit of pressure.
    Normally aspirated (non-booted) creates maximum MAP of 1 bar (atmospheric);
    Forced Induction (boosted) creates maximum MAP above 1 bar:
    2 bar = 1 bar boost + atmospheric, 3 bar = 2 bar boost + atmospheric;
    each requires the correct MAP sensor and sensor scale factor (in the COS).
    What controls boost:
    SC: speed of impellers (driven via belt by engine crank);
    TC: exhaust gas flow and waste gate (controlled by several different methods).
    Jan 2005
    Non-boosted: 1 bar (max MAP = atmospheric);
    Boosted: 2 bar (1 bar on top of atmospheric), or 3 bar (2 bar on top of atmospheric); each requires correct MAP sensor (and COS).
    Then there's the whole inertial supercharging thing... !split hairs.
    I owe you an ftp transfer.
    I edited my post to add more info.
    TA, no worries, take your time on the ftp transfer.
    Nov 2006
    Thx Guys, I get it:
    My car normally aspirated is 1 Bar. With a Super or Turbo Charger depending on my boost I can be higher Bar. Essentially a 3 Bar engine is one mean mofo.
    joecar - I found a bolt what should I do with it?
    Oct 2004
    Quote Originally Posted by TAQuickness
    Am I owed one
    Andrew
    EFILive Crew
    Quote Originally Posted by NewV
    Thx Guys, I get it:
    NewV,
    If you found a bolt, then it is not a lost bolt anymore, so I am not in charge of it.
    Joe
    Edit: Or just post it (the bolt) in the Lounge in the Lost Bolts thread.
  1. Replies: 10
    Last Post: December 30th, 2007, 04:57 PM
