Results 1 to 5 of 5
Thread: Force motor current
    Lifetime Member 87gmc's Avatar
    Apr 2004
    Default Force motor current
    What exactly does Force motor current do on the trans pressure? I noticed my friends car has a hypertech tune and for firmer shift it adjusted the force motor current. Why also do 99-00 have a negative and positive one where as the 01-02 only have a force motor current.
    As force motor current decreases (toward 0.0 A), the line pressure goes up.
    The "force motor" is also called (in more recent times) the "Pressure Control Solenoid".
    Minimum line pressure: PCS current is 1.1 A.
    Maximum line pressure: PCS current is 0.0 A.
    So, if something goes wrong (PCS signal wire breaks), the line pressure will go to maximum so the trans can protect itself.
    Maximum line pressure is set mechanically by a screw adjustment in the back of the PCS.
    I've never heard of negative PCS current...
    the PCS current is the RMS (root-mean-square) current produced by the PWM (pulse-width-modulated) square wave voltage that the PCM drives on the PCS signal wire, so it can never be physically negative... ...eh... maybe I missed the meaning of your last sentence...???
    Apr 2004
    open a bin file of a 99-00 in efilive tune and you will see a pos and neg force motor control
    87gmc,
    I don't doubt you, I just find it quite strange (I don't know how to interpret it)...
    I don't have a 99-00, can you post a screenshot of it...
    Joe
    Some operating systems use a single pressure to current table. And therefor only display a single table.
    Some operating systems use two pressure to current tables. One for when the pressure is increasing (positive), one for when the pressure is decreasing (negative). And therefor display two tables.
  1. camaro 2010 e-force
    By franckrem in forum E37, E38 & E67 PFI ECM's
    Last Post: May 24th, 2010, 08:00 AM
  2. G-Force
    By killerbee in forum General (Diesel)
    Last Post: December 27th, 2008, 12:05 PM
  3. Force regeneration with EFILive?
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 10th, 2008, 09:39 AM
  4. Force open loop just at idle
    By RonSS in forum Gen III V8 Specific
    Last Post: December 30th, 2006, 12:59 PM
  5. force motor current
    By 69camaro5speed in forum General
    Last Post: December 8th, 2006, 10:47 AM
