Results 1 to 3 of 3
Thread: setting cam sync
    Oct 2006
    Default setting cam sync
    Hi,
    As I understand it, after having the distributor out of a 96-01?? vortec engine, you have to set the cam sync timing. We had to borrow a snap-on scanner to do this, but I was wondering...
    Will the EFI LIVE software / scanner allow the user to view the cam sync timing to set it properly on these vortec engines?
    I am getting into PCM programming, and reading everything I can find on this stuff, but that was one question I have never found an answer to.
    thanks,
    rb
    Aug 2006
    I have EFILive and a 12200411 PCM on a 98 GMC Vortec. I don't think EFILive will show CMP offset. If it does, I've never seen it.
    Senior Member Chuck L.'s Avatar
    Feb 2006
    Thumbs up It will
    Quote Originally Posted by Lextech View Post
    if you update the program. Just did that last nite, and the
    PID, GM.CMPRET is there.
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
  1. Setting up V2 for BBL...
    By joecar in forum Black Box Logging
    Last Post: May 2nd, 2011, 01:41 PM
  2. Help setting up LC1
    By Slow73 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2009, 03:51 PM
  3. How to sync with Monte Carlo
    By eaglei022 in forum EFILive V4
    Last Post: May 12th, 2009, 11:09 AM
  4. fan setting for ls2?
    By minytrker in forum Gen IV V8 Specific
    Last Post: June 15th, 2007, 03:45 AM
  5. Setting up PLX with V2
    By mtnman in forum FlashScan V2
    Last Post: February 8th, 2007, 07:20 AM
