Did it change the IFR angle for you as well?
Andrew
EFILive Crew
Am going to be flying out to Sydney shortly but I'll have to catch up with you next week Tordne to sort it out.
Cool mate, have a safe trip.
Andrew
EFILive Crew
the link up top is dead, please fix it
The tutorial is actually included in the installed software. But I'll update the link as well.
Andrew
EFILive Crew
Has anyone installed this sender and checked their fuel pressure? Does it have to be this exact sender? I was thinking about adding this to my car.
Thanks,
Bill
2011 Camaro 2SS/RS L99 RJT
CAI, Inc. Cold Air Induction;ADM Scoop
Rx Catch Can;Rx Breather;Roto-Fab Washer Container
VMax Ported RJT Throttle Body
XSPower Headers and XSPower 3" Exhaust System
Elite Engineering Tunnel Brace,
Gorilla Wheel Lock System;
Tinted Windows 35%;EFILive Tune
I have and it works as advertised. I suppose you could use any 0-5vdc pressure sensor with the proper range. The autometer isn't expensive though.
www.efialchemy.com
www.greatamericancarwar.com
It is like $140 at summit for the harness and sensor.Originally Posted by Doc
Bill
Don't bother with the pigtail. Just goto your dealer and get a 98 ECT sensor pigtail. You don't need the length of the autometer harness- well you should'nt if you are planning on using the existing EGR wiring.
www.efialchemy.com
