Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 83
Thread: Tutorial: Log Fuel Pressure in EFILive
  1. #41
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Quote Originally Posted by Doc
    Don't bother with the pigtail. Just goto your dealer and get a 98 ECT sensor pigtail. You don't need the length of the autometer harness- well you should'nt if you are planning on using the existing EGR wiring.
    I was not sure if I just wanted to wire straight to EFILive or go thru EGR wiring. It looks like the EGR might be the best way. My car is a 2001 without EGR.
    What do you think Doc?
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
  2. #42
    Lifetime Member Doc's Avatar
    Oct 2005
    Yeah Bill, I was thinking of that when I left off last- 2001 no egr.(Busy putting in my motor right now) No worries. You can still run the wires from the pcm it'self. The EGR option is the easiest to take advantage of a power supply and voltmeter on a system that is not used on your car.
    www.efialchemy.com
    www.greatamericancarwar.com
  3. #43
    Lifetime Member Beer99C5's Avatar
    Jul 2006
    I agree! The EGR for the 5V supply works great and data feed for the EGR volts set to a custom PID is beautiful!
    Jim
    1999 C5 A-4 Convertible
    1 of 245 Nassua Blue 99 Vert's, Blackwing, LS6 Intake, 42 # Injectors, Two Stage Nitrous System- Dry and a Wet Plate, EFI Live Scan/Tune V2, 1999 PCM with 2002 COS 5 OS Custom Nitrous Panel.
    Maine USA
  4. #44
    Nov 2003
    Is the wiring harness already wired for the EGR or will I need the pins and wiring? What size pins are in the PCM connector? I have not looked at the PCM yet.
    Thanks.
    Bill
  5. #45
    Nov 2003
    Just got the sender and harness in. My wires are different collors than what is in the tutorial. I have a purple and a black and gray. The purple should be the 0-5vdc signal. I assume the black is ground and the gray is +5vdc. Does that sound right?
    Thanks,
    Bill
  6. #46
    Nov 2003
    Talking
    I got this wired up to my EGR PCM pins. Thanks DOC for your help and PCM pins. It is working great now. My Fuel Pressure is running about 60 at idle.
    Thanks everyone for the help.
    Bill
  7. #47
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Anyone does this with Australian cars?
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
  8. #48
    Member VT LS1 NZ's Avatar
    Quote Originally Posted by oztracktuning
    I have it working fine on mine.
    Just had to add the wires & enable .
    856RWHP 408 Supercharged LS1 Holden Commodore.
  9. #49
    Mar 2004
    yes
  10. #50
    Nov 2005
    In Australian cars are the wires there already or do the connectors with wires need to be put in ie. are they vacant.
    Oztrack
    www.oztrack.com.au
  1. Fuel Rail Pressure's relationship to fuel economy.
    By duramaximizer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 28th, 2010, 01:18 PM
  2. EFILive AutoVE Tutorial help
    By -=Mod=- in forum Gen III V8 Specific
    Last Post: September 28th, 2009, 03:54 AM
  3. LOW FUEL PRESSURE logging for low fuel pressure nirtous systems
    By WiseGuyZ06 in forum External A/D inputs
    Last Post: October 11th, 2007, 12:56 PM
  4. EFILive AutoVE Tutorial & 1998
    By eboggs_jkvl in forum General
    Last Post: June 19th, 2006, 03:13 PM
  5. Tutorial for tuning VE using LTFT's using EFILive ??
    By Thedude in forum General (Petrol, Gas, Ethanol)
    Last Post: October 18th, 2005, 10:55 AM
