2000 SS M6
Ok guys i have a few questions. First off im running open loop still AUTO VE'ing so im running everything just like it says in the tutorial. When the car first starts up and idles, well actually it can pretty much idle all day and until i drive the car the AFR usually is about 15-16:1 and sometimes higher I have done RAFIG numerous times. Once i drive it for a while and go and sit and idle it is where it needs to be... but why does it run so lean before i drive it? I have a file of first start idle if i can figure out how to post it....
My next question is when im open loop, auto ve mode, maf not hooked up does my car run off of the back up ve table or main ve table? Back up i would guess. Is there a way to make it run off the Main VE table without hooking the maf back up or do i have to run a COS to do this? ALso what about my spark tables, when i go WOT does it run off the Optimal Spark table or run a mixture of high and low octane tables?
