Results 11 to 20 of 26
Thread: Car started running rich and miss firing
    Jan 2005
    you can log them, but if they are bad, how will you know what good ones look like (past logs maybe)?
    i don't run NBO2's so I can't tell you what to look for, but I know they'll kick your ass if they're bad
    May 2006
    Quote Originally Posted by TAQuickness
    Damn, how much are they anyhow, not too expenssive I assume?
    2000FRC 408ci 520rwhp - 498rwtq Callies Crank, Eagle Rods, Diamond Pistons, Absolute Speed Heads, 244 248 cam, LG Headers, FAST 90, TPIS 90, ATI UD, 11.6cr, EFILive, LC-1 Wideband, RPM Trans, DTE brace, Spec 3+, Momo, etc...
    Custom N2O direct port setup with stand alone fuel system in the works
    Idle and Revs
    Jan 2005
    not bad, Bosche 13111's are about 75 each in my neck of the woods.
    May 2006
    I just dont want to fork out 150 bux and not fix the problem
    Idle and Revs
    Jan 2005
    compare your logs to old logs and see how it looks.
    May 2006
    Thats what sucks, I never logged the O2 sensors
    Idle and Revs
    Oct 2003
    No DTCs?
    joel
    Your WB says you're running rich;
    Log the following:
    LTFT1 or LONGFT1
    LTFT2 or LONGFT2
    HO2S11
    HO2S21
    If your NBO2 sensors appear to be working, the HO2S11/HO2S21 will:
    at WOT: peg at something like 800+mV;
    at PT: switch up/down (i.e. cross 450mV in each direction) [almost] repeatedly;
    If they are doing this, then what do the LTFT's read...?
    Does this correlate with the WB sensor...?
    Are the LTFT's deviating from zero by more than 5% (say)...?
    Rich or lean...?
    Are you running a MAF...?
    If so, log MAF and MAFFREQ and see that they correlate to TPS and RPM.
  9. #19
    May 2006
    Well this problem is still on-going... I dont know what else to do.
    I've checked all of the following:
    Injectors (not leaking)
    Plugs (nice and brown)
    Plug wires MSD (look to be working fine)
    Vacum hoses (all fine)
    Checked for broken valve springs (checked all fine)
    Checked the header primary temperatures with an infrared thermometer and there was some differences off about 100F on a couple of cylinders. Need to check again tomorow to see if the readings are the same.
    I appreciate all of you guy's help, but I'm still too new with EFILive to know what to and how to log certain parameters and know how to read the results.
    Idle and Revs
  10. #20
    Use the EFILive scan tool to do the Cylinder Balance test.
    Then you may also want to do a compression/leakdown test.
  1. running rich between shifts??
    By smslyguy in forum Gen III V8 Specific
    Last Post: October 8th, 2009, 09:53 AM
  2. 5.7 running rich.
    By DmaxHawk in forum Vortec V6/V8 Specific
    Last Post: January 21st, 2009, 06:40 AM
  3. COS3 running rich
    By southern in forum Custom Operating Systems
    Last Post: September 17th, 2008, 04:56 AM
  4. Why is it running rich?
    By Garry in forum Gen III V8 Specific
    Last Post: May 10th, 2008, 05:05 AM
  5. It's running a little rich
    Last Post: January 23rd, 2007, 02:30 PM
