The cylinder balance test is not very consistent because the idle is bouncing up and down when rough. As for the compression test I'm doing it tomorrow.Originally Posted by joecar
2000FRC 408ci 520rwhp - 498rwtq Callies Crank, Eagle Rods, Diamond Pistons, Absolute Speed Heads, 244 248 cam, LG Headers, FAST 90, TPIS 90, ATI UD, 11.6cr, EFILive, LC-1 Wideband, RPM Trans, DTE brace, Spec 3+, Momo, etc...
Custom N2O direct port setup with stand alone fuel system in the works
Idle and Revs
I got a code P0200 "Injector Circuit Malfunction"
Anybody know what this is?
Idle and Revs
P0200 = PCM detected incorrect voltage on injector driver circuit(s) for 5 seconds or longer.
Check the INJ fuse (and find the cause if it's popped);
Check for voltage at each injector connector;
Check for pulsing/"blinking" voltage with engine cranking,
if not, then check for short or open.
You have either:
a. one or more electrically open injector(s);
b. one or more injector circuit(s) that are open or shorted (to either ground, or to voltage, or to each other);
c. one or more bad injector connectors and/or harness connectors;
d. one or more failed injector driver(s) in the PCM;
e. a bad ground somewhere;
f. a bad connection to the INJ fuse, or the INJ fuse is blown (see "shorted" in b. above).
Thanks, I'll look it up. Would this be the cause for this whole problem?Originally Posted by joecar
How do I check the blinking voltage? Sorry for the dumb questions
Idle and Revs
Darkness,Originally Posted by Darkness
Not dumb... it would be dumb to not know AND not ask...
Can use a LED voltage probe (looks like a pointy screwdriver with red and green LEDs inside the handle, and a long wire lead off the handle to a crocodile clip... green lights up on positive voltage, red lights up on negative voltage; available at parts stores for $20), connect across injector harness connector, flashes as engine cranks...
Or can use injector connector test light (plugs into injector harness connector and flashes while engine is cranking; some parts stores have these, you need the GM variant, these are more expensive and less verstile than LED voltage probe)...
Or can borrow a scopemeter (will show a squarewave) if you know the right person...
May be able to use a DMM, but it's more difficult... you'll see a varying DC voltage while engine cranks, may be able to see an AC voltage... some DMM's have a Hz function, gives a reading matching RPM / 2.
You'll need a DMM to check for injector resistance and wire continuity anyway.
Goto www.ls2.com and look at their forum's diagnostic sections (courtesy of Elmer, good job )... they have diagnostic proceedures for just about any DTC... if you can't find it, I'll try to find it... it's sectioned by year/make/model, but most of these have the same exact diagnostic procedure.
Joe
