Results 1 to 10 of 13
Thread: Full Reflash
    Oct 2006
    Default Full Reflash
    Ok went to do a Custom OS flash but got a warning
    "To reduce the risk of failure, EFILive recommends removing
    your PCM from the vehicle and using a bench harness to
    perform the full reflash.
    Alternatively, the PCM may be left in the vehicle, provided
    that a star connector is used to isolate the PCM from the
    class-2 network during reflashing.
    Programming the target PCM in-vehicle, without isolating it
    from the class-2 network, is STRONGLY discouraged.
    EFILive accepts no responsibilty whatsoever if your PCM is
    permanently damaged during a full reflash procedure."
    A star connector? Class2 network?
    Removing the PCM from vehicle ?
    2006 Trailblazer
    Oct 2004
    Just the normal recommendation stuff and that it is your educated risk.
    There is a period of a few seconds, where the traffic light indicator is red, where the bootloader on the PCM is updated where you are at risk. Once the traffic light goes amber/yellow there is no more risk than performing a calibration only flash. Thats as I understand it anyway.
    I would have performed 10's of full flash operations on my car alone with no issue at all! Holden's may be a little different in that there is nothing but the PCM on the bus - all other modules are ALDL
    Andrew
    EFILive Crew
    tunedbyGM,
    What Andrew says;
    Also, just to increase the safety "envelope", make sure all accessories are turned OFF (stereo, headlights, daytime running lights, dome light (close doors), etc) prior to flashing.
    Aug 2005
    tunedbyGM,
    What Andrew says;
    And if you have an aftermarket stereo with XM, pull the radio fuse.
    Quote Originally Posted by dc_justin
    Good one.
    Disable anything that draws current.
    Aug 2005
    Good one.
    Not only that, but as Paul told me when I asked why I couldn't use high speed, aftermarket XM systems have a problem shutting up when asked to do so and can screw up the communications between flashscan and the pcm.
    Oct 2006
    Thanks all , but just for kicks , what exactly is a class 2 network and a star connector ?
    Just to satisfy my thirst for knowledge .
    I have factory OnStar and figured it would need to be disabled , but did not think about XM radio.
    2006 Trailblazer
    Aug 2005
    Quote Originally Posted by tunedbyGM
    You shoudl be fine, as those are both GM systems and play nicely on the network. it's when you throw in aftermarket systems that things can get a little problematic.
    MY rule of thumb is if you can read at high speed or can perform a calibration-only flash at high speed, you should be able to perform a full flash without problem. On 512Kb PCMs, it's the first 16Kb that are the critical part, on 1MB PCMs, it's the first 32Kb. At high speed, your flash would have to fail in the first 4-5 seconds for there to be a problem...
    Ah, ok, so the rule is:
    "Disable anything that may interfere with bus comms, and don't use accessories that may cause a voltage-drop/current-draw"
    Jan 2005
    Class 2 network is the communication buss the PCM and other on board modules use to communicate
    Star connector is one that removes the PCM from the network for dedicated reflashing.
    As far as rule's of thumb go - Only do full flashes at the house. Would suck to have a full flash fail at work or on the side of the road and leave you stranded.
  1. T43 Full Reflash
    By ntrimm in forum Gen IV V8 Specific
    Last Post: April 19th, 2009, 11:59 PM
  2. Cant do a full reflash on LMM?
    By dmaxallitech in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 21st, 2008, 03:00 PM
  3. Always a full reflash?
    By 1SlowHoe in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2008, 04:05 AM
  4. Full reflash ?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 01:05 PM
