Results 1 to 2 of 2
Thread: Knock modes
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default Knock modes
    B6251 If this is set to disable above 60% Throttle does this mean the engine has no knock protection above 60% throttle ?
    Im after some more information about the knock modes. It seem there are two:
    RPM mode and TPS mode ?
    Jun 2005
    It runs in 3 different knock modes based on the enablers: TPS mode, RPM mode, and Cylinder or Engine mode (set in B6243).
    On mine, TPS mode is enabled if:
    TPS% is changing more than 3% every 0.25seconds and 2%<TPS<60%.
    RPM mode is enabled if:
    RPMs are changing more than 15rpm every 0.25seconds and 600<RPM<6,000.
    If both are active, then the PCM will use the highest value from either one of the tables for the current conditions. If neither one are active, the PCM will revert to the knock mode set in B6243 - which is for more steady throttle/cruise conditions.
  1. switched modes??
    By truethinker in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 16th, 2012, 02:03 PM
  2. LLY Duramax Scan Modes
    By Cougar281 in forum General
    Last Post: August 11th, 2008, 02:30 PM
  3. Setting up the N2O Modes
    By BowlingSS in forum Custom Operating Systems
    Last Post: January 25th, 2008, 05:35 AM
  4. What do the different TCC modes mean?
    By thunder550 in forum General
    Last Post: May 6th, 2006, 10:36 AM
  5. Making both trans modes the same
    By 34Koop in forum General (Petrol, Gas, Ethanol)
    Last Post: July 22nd, 2005, 05:53 PM
